Here is my etc/locale.conf file:
cat locale.conf
LANG=en_US.UTF-8
LC_ADDRESS=en_US.UTF-8
LC_IDENTIFICATION=en_US.UTF-8
LC_MEASUREMENT=en_US.UTF-8
LC_MONETARY=en_US.UTF-8
LC_NAME=en_US.UTF-8
LC_NUMERIC=en_US.UTF-8
LC_PAPER=en_US.UTF-8
LC_TELEPHONE=en_US.UTF-8
LC_TIME=en_US.UTF-8
But you do locale command and you get this:
[mark@mark-optiplex9020 etc]$ locale
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
LANG=en_US.UTF-8
LC_CTYPE="en_US.UTF-8"
LC_TIME=en_US.UTF-8
LC_COLLATE="en_US.UTF-8"
LC_MESSAGES="en_US.UTF-8"
LC_NAME=en_US.UTF-8
LC_ALL=
Is the last entry supposed to end in an equals sign, or should something be in there?
I can probably retrieve an older copy of these files from my timeshift backups, but don’t want to do it blind.
Thanks in advance for any advice.
[jman@jman-virtualbox ~]$ locale
LANG=en_US.UTF-8
LC_TIME=en_US.UTF-8
LC_NAME=en_US.UTF-8
LC_ALL=
Matches what I have well. Seems normal.
Everything seems to work but never seen those error messages before.
You could create them manually to resolve this section:
mine for example exists in here:
[jman@jman-virtualbox ~]$ cd /usr/lib/locale/C.utf8/
[jman@jman-virtualbox C.utf8]$ ls
LC_ADDRESS LC_COLLATE LC_CTYPE LC_IDENTIFICATION LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER LC_TELEPHONE LC_TIME
Although I will say I wasn’t able to locate the LC_ALL
directory.
I did find out that LC_ALl is supposed to stay blank, it’s for troubleshooting.
This link:
Update Mirrors (Arch) script not working in Welcome v3.41-2 - #10 by manuel seemed to point to the setting being commented out if a merge was done improperly. I found the same thing on my system, rebooted but its still there.
manuel
April 22, 2024, 5:14pm
6
Changed your earlier post to look more readable…
Fixed. After running sudo locale gen it all came back. Uncommenting the entry in the locale gen file was the necessary step.
Locale is behaving fine now, no error messages:
[mark@mark-optiplex9020 ~]$ locale
LANG=en_US.UTF-8
LC_CTYPE=“en_US.UTF-8”
LC_TIME=en_US.UTF-8
LC_COLLATE=“en_US.UTF-8”
LC_MESSAGES=“en_US.UTF-8”
LC_NAME=en_US.UTF-8
LC_ALL=
system
Closed
April 24, 2024, 5:15pm
8
