Yes, the LTS kernel gets all the same features as the mainline kernel. It just gets them slower. Instead of getting newer features every couple of months you get new kernel features every ~11 months or so.
In the case of btrfs, this is usually better. There have been a few cases where the mainline kernel has gotten updates which negatively impacted btrfs in some way. These issues are always fixed quickly but if you are on LTS you would never see those issues at all.
Thanks a lot @dalto
I will look how to install LTS and make it default!
Then I would later remove the mainline kernel as I see no point in having/updating it regularly!
You can if you would like to. My philosophy is it is better to have two kernels installed âjust in caseâ but it certainly isnât a requirement. Especially if you are using LTS.
Me too, previously when I was on EXT4 I had both for the âjust in caseâ, which is not likely to happen.
Moreover if the âjust in caseâ happened I am on BTRFS and have snapshots of system I can roll back to. So I see no real critical need for another kernel.
I am always having something to boot from snapshots.
Please correct me if I donât understand (as usual)
Would it be necessary to update Grub after LTS install and after uninstalling the other?
What if an update to Snapper or BTRFS Assistant⌠or⌠that uses something new in âcurrentâ kernel and it is not yet in LTS?
Wonât this break it?
I installed EOS Cinnamon on my main desktop machine in January 2021. Since then Iâve had zero crashes, two balky apps, and one incident of not being able to update from US mirrors. These issues all resolved themselves in 2-3 days with no intervention from me other than running an update. I trust EOS so much I use it professionally when Iâm teleworking. YMMV, but Iâve stopped distro hopping.
Installed EOS: September 2020
Re-installs: 0
Crashes: 0
Issues: Yes, but usually fixed upstream within 24 hours apart from (a very few) AUR Apps.
Issues which made computer unusable: 0
Stable? YES!
Tips: Keep your mirrors updated, Reflector simple is good for this. Deal with pacnew files, and update at least once a week. Donât panic and have fun.
If you were really a long time EndeavourOS user, youâd know that this âinstabilityâ is just a myth (unless youâre really unlucky with the hardware you have, but in that case, pretty much any Linux distro will be unstable).
Packages on EndeavourOS receive daily updates, so in that sense, it is âunstableâ. This certainly does not mean âprone to breakingâ, which so many ignorant Tubers and âtechâ websites like to constantly parrot.
The fact is that EndeavourOS, thanks to itâs Arch base, is as robust of a general desktop operating system as they get, as long as you update it frequently and donât break it yourself (user mistake).
There is no guarantee that it wonât. But it will probably be a minor inconvenience that is easy to fix. Honestly, I am more worried about hardware failure than the OS breaking on its own.
That wonât happen. Snapper wouldnât make a change that depended on a brand new kernel feature. Snapper(and virtually every other software package) needs to run on older kernels too.
Snapper is developed by Suse and I believe the most recent version of OpenSuse Leap is using kernel 5.14. There are probably supported versions with much older kernels than that.
The current Arch LTS kernel is 5.15 for reference.
The chance of finding a mainstream application that wouldnât work with the most recent LTS kernel is almost none. Even even if you went back 2 additional LTS releases to 5.04 you would have trouble finding software that wouldnât run on it.
The situation is almost exactly the same for me. I switched from Antergos to EOS around November 2019. which worked flawlessly for a year. Then, due to a machine change, I installed the system in November 2020, and since then it has not been necessary to reinstall, and the very rare package errors were usually fixed within a day. So, a rolling release distribution that fulfills the stability of point release based distributions. I even forgot about Debian, even though itâs a big word for me.
