Hello, Iḿ searching and searching … where are located the category ´my posts´ in the forum?, Thanks.
I see … it is difficult to find, thanks!.
I see you’re used to the Arch Linux forums. Note that instead of marking the title with [Solved], you can just click the solution button at a post itself.
