I’m attempting to install EndeavourOS Neo under VirtualBox 7.0.22 on a Debian Stable host. ISO seems to boot fine, I get to what looks like the command line with some automated login info, and then I get a blank screen. Typing on the keyboard does nothing.
I tried using the VirtualBox EFI setting with the same result.
I’m using the VMSVGA display setting with 256mb of video memory with 3D acceleration enabled.
EDIT:
I needed to be patient. It takes awhile for the desktop to startup under VirtualBox.
