I install the system, I do not know if I did something wrong but I put /efi to the first fat32 partition and install the system in the P7, now when it boots the other systems do not appear in the entries, I go to the terminal:
[alnone@alnone-inspiron3583 ~]$ LANG=C sudo pacman -S os-prober
[sudo] password for alnone:
warning: os-prober-1.81-1 is up to date -- reinstalling
resolving dependencies...
Package (1) Old Version New Version Net Change
extra/os-prober 1.81-1 1.81-1 0.00 MiB
Total Installed Size: 0.06 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [--------------------------------------] 100%
(1/1) checking package integrity [--------------------------------------] 100%
(1/1) loading package files [--------------------------------------] 100%
(1/1) checking for file conflicts [--------------------------------------] 100%
:: Processing package changes...
(1/1) reinstalling os-prober [--------------------------------------] 100%
(1/2) Arming ConditionNeedsUpdate...
(2/2) Checking which packages need to be rebuilt
[alnone@alnone-inspiron3583 ~]$ nano /etc/default/grub
[alnone@alnone-inspiron3583 ~]$ LANG=C sudo grub-mkconfig -o /boot/grub/grub.cfg
sudo: grub-mkconfig: command not found
[alnone@alnone-inspiron3583 ~]$ LANG=C update-grub
bash: update-grub: orden no encontrada
[alnone@alnone-inspiron3583 ~]$ sudo -i
[root@alnone-inspiron3583 ~]# grub-mkconfig -o /boot/grub/grub.cfg
-bash: grub-mkconfig: orden no encontrada
[root@alnone-inspiron3583 ~]# LANG=C grub-mkconfig -o /boot/grub/grub.cfg
[root@alnone-inspiron3583 ~]# pacman -S update-grub
error: no se ha encontrado el paquete: update-grub
[root@alnone-inspiron3583 ~]# yay -S update-grub
-> Evite ejecutar yay como root/sudo.
AUR Explicit (1): update-grub-0.0.1-8
Sync Dependency (1): grub-2:2.12-2
:: (1/1) PKGBUILD Descargado : update-grub
1 update-grub (Archivos de compilación existen)
==> ĀæPaquetes a limpiar antes de compilar?
==> [N]inguno [A]Todos [Ab]ortar [I]nstalados [No]Instalados o (1 2 3, 1-3, ^4)
==> A
:: Borrando (1/1): /tmp/yay/update-grub
HEAD estĆ” ahora en d0b7d22 Update .SRCINFO (really sorry for the commit spam y'all, I haven't slept in two days)
==> ĀæDiffs a mostrar?
==> N
==> ERROR: Ejecutar makepkg como superusuario no estƔ permitido ya que puede causar daƱos
permanentes y catastróficos a su sistema.
-> error descargando fuentes: /tmp/yay/update-grub
context: exit status 10
:: (1/1) Analizando SRCINFO: update-grub
resolviendo dependencias...
buscando conflictos entre paquetes...
Paquete (1) Versión nueva Diferencia neta Tamaño de la descarga
core/grub 2:2.12-2 33.67 MiB 6.84 MiB
TamaƱo total de la descarga: 6.84 MiB
Tamaño total de la instalación: 33.67 MiB
:: ¿Continuar con la instalación? [S/n] s
:: Obteniendo los paquetes...
grub-2:2.12-2-x86_64 6.8 MiB 4.51 MiB/s 00:02 [--------------------------------------] 100%
(1/1) comprobando las claves del depósito [--------------------------------------] 100%
(1/1) verificando la integridad de los paquetes [--------------------------------------] 100%
(1/1) cargando los archivos de los paquetes [--------------------------------------] 100%
(1/1) comprobando conflictos entre archivos [--------------------------------------] 100%
:: Procesando los cambios de los paquetes...
(1/1) instalando grub [--------------------------------------] 100%
:: Install your bootloader and generate configuration with:
# grub-install ...
Dependencias opcionales para grub
freetype2: For grub-mkfont usage [instalado]
fuse3: For grub-mount usage [instalado]
dosfstools: For grub-mkrescue FAT FS and EFI support [instalado]
lzop: For grub-mkrescue LZO support
efibootmgr: For grub-install EFI support [instalado]
libisoburn: Provides xorriso for generating grub rescue iso using grub-mkrescue
os-prober: To detect other OSes when generating grub.cfg in BIOS systems [instalado]
mtools: For grub-mkrescue FAT FS support [instalado]
:: Ejecutando los «hooks» de posinstalación...
(2/2) Updating the info directory file...
-> error compilando: update-grub-exit status 10
-> Ha fallado al instalar los siguientes paquetes. Una intervención manual es requerida:
update-grub - exit status 10
[root@alnone-inspiron3583 ~]# pacman -S os-prober
advertencia: os-prober-1.81-1 estƔ actualizado -- reinstalƔndolo
Paquete (1) Versión antigua Versión nueva Diferencia neta
Tamaño total de la instalación: 0.06 MiB
TamaƱo neto tras actualizar: 0.00 MiB
(1/1) reinstalando os-prober [--------------------------------------] 100%
/usr/bin/grub-mkconfig: lĆnea 270: /boot/grub/grub.cfg.new: No existe el fichero o el directorio
/usr/bin/grub-mkconfig: line 270: /boot/grub/grub.cfg.new: No such file or directory
[root@alnone-inspiron3583 ~]# update-grub
-bash: update-grub: orden no encontrada
[root@alnone-inspiron3583 ~]# LANG=C update-grub
[alnone@alnone-inspiron3583 ~]$ pacman -Q grub
grub 2:2.12-2
[alnone@alnone-inspiron3583 ~]$ LANG=C sudo parted -l
Model: PC SN520 NVMe WDC 256GB (nvme)
Disk /dev/nvme0n1: 256GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 1537MB 1536MB fat32 boot, esp
2 1537MB 3064MB 1527MB linux-swap(v1) swap
3 3064MB 45.6GB 42.5GB ext4
4 45.6GB 94.4GB 48.8GB ext4
5 94.4GB 146GB 52.1GB btrfs
6 146GB 210GB 63.6GB ext4
7 210GB 256GB 46.0GB ext4
[alnone@alnone-inspiron3583 ~]$ LANG=C efibootmgr
BootCurrent: 0004
Timeout: 0 seconds
BootOrder: 0004,0002,0006,0001,0000,0003
Boot0000* MX21 HD(1,GPT,1f8b0ce7-b5a4-4236-8019-565e23b47888,0x800,0x2dc800)/\EFI\MX21\grubx64.efi
Boot0001* MX23 HD(1,GPT,1f8b0ce7-b5a4-4236-8019-565e23b47888,0x800,0x2dc800)/\EFI\MX23\grubx64.efi
Boot0002* garuda HD(1,GPT,1f8b0ce7-b5a4-4236-8019-565e23b47888,0x800,0x2dc800)/\EFI\garuda\grubx64.efi
Boot0003* UEFI: PC SN520 NVMe WDC 256GB, Partition 1 HD(1,GPT,1f8b0ce7-b5a4-4236-8019-565e23b47888,0x800,0x2dc800)/\EFI\boot\bootx64.efi0000424f
Boot0004* Linux Boot Manager HD(1,GPT,1f8b0ce7-b5a4-4236-8019-565e23b47888,0x800,0x2dc800)/\EFI\systemd\systemd-bootx64.efi
Boot0006* ubuntu HD(1,GPT,1f8b0ce7-b5a4-4236-8019-565e23b47888,0x800,0x2dc800)/\EFI\ubuntu\shimx64.efi
[alnone@alnone-inspiron3583 ~]$ LANG=C cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=6693-9A38 /efi vfat fmask=0137,dmask=0027 0 2
UUID=61f4557b-6f8d-4ba4-b130-3e852a6e69e5 / ext4 noatime 0 1
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
[alnone@alnone-inspiron3583 ~]$ LANG=C cat /etc/default/grub
# GRUB boot loader configuration
GRUB_DEFAULT=0
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="Arch"
GRUB_CMDLINE_LINUX_DEFAULT="loglevel=3 quiet"
GRUB_CMDLINE_LINUX=""
# Preload both GPT and MBR modules so that they are not missed
GRUB_PRELOAD_MODULES="part_gpt part_msdos"
# Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'hidden' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT_STYLE=menu
# Uncomment to use basic console
GRUB_TERMINAL_INPUT=console
# Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `videoinfo'
GRUB_GFXMODE=auto
# Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX=keep
# Uncomment if you want GRUB to pass to the Linux kernel the old parameter
# format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_COLOR_NORMAL="light-blue/black"
#GRUB_COLOR_HIGHLIGHT="light-cyan/blue"
# Uncomment one of them for the gfx desired, a image background or a gfxtheme
#GRUB_BACKGROUND="/path/to/wallpaper"
#GRUB_THEME="/path/to/gfxtheme"
# Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
#GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU=y
# Probing for other operating systems is disabled for security reasons. Read
# documentation on GRUB_DISABLE_OS_PROBER, if still want to enable this
# functionality install os-prober and uncomment to detect and include other
# operating systems.
#GRUB_DISABLE_OS_PROBER=false
This why you are having problem with grub. Grub is simply non-functional and unneeded on your system.
If you want to let your EnOSā systemd-boot manage booting of your other Linux systems (which use grub), read carefully through the following article to get acquainted with systemd-boot:
I see, well that is to difficult for my level, i think it is better to reinstall, now how do we do that right in Calamares?, the options were /efi, in Fat32 (without to format, of course) would you tell me what i did wrong in Calamares? thanks.
during the install process you choose the boot loader. Systemd is the default but you can switch it to grub if you prefer to use grub as many other users here do.
If so, from now on use the reply button under the post you want to reply to for the person in question to get notified.
So, for example, if your MX23 is installed and functional, do the following to create a boot entry for it:
sudo nano /efi/loader/entries/mx23.conf
and put the following in:
title MX Linux 23
efi /EFI/MX23/grubx64.efi
save the file.
Reboot and check if you have a boot entry for MX Linux 23 on your EnOSā systemd-boot menu.
Try booting it up and see if it will take you to MX23 grub boot menu.
If this works. Do the same for all the other systems. Check the output of the efibootmgr to see what efi binary and what location you need to use in each case.
While you was be writing the post I decided to reinstall, well, the thing was that I did the installation in a hurry, did not consider the options and continued ⦠and it was left with (systemd/boot) that comes by default (bad idea).
Now after uncommenting os-prober ⦠and sudo grub-mkconfig -o /boot/grub/grub.cfg everything is in order.
type or paste calnone@alnone-inspiron3583 ~]$ sudo -i
[sudo] contraseƱa para alnone:
[root@alnone-inspiron3583 ~]# os-prober
/dev/nvme0n1p3:MX 21.3 Wildflower (21.3):MX:linux
/dev/nvme0n1p4:MX 23.2 Libretto (23.2):MX1:linux
/dev/nvme0n1p6:Linux Mint 21.3 Virginia (21.3):LinuxMint:linux
ode here
[root@alnone-inspiron3583 ~]# LANG=C sudo grub-mkconfig -o /boot/grub/grub.cfg
Generating grub configuration file ...
Found background: /usr/share/endeavouros/splash.png
Found linux image: /boot/vmlinuz-linux
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux.img
Found fallback initrd image(s) in /boot: intel-ucode.img initramfs-linux-fallback.img
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot entries.
Found MX 21.3 Wildflower (21.3) on /dev/nvme0n1p3
Found MX 23.2 Libretto (23.2) on /dev/nvme0n1p4
Found Linux Mint 21.3 Virginia (21.3) on /dev/nvme0n1p6
Adding boot menu entry for UEFI Firmware Settings ...
done
