Hi, normally EndeavourOS works seamlessly out of the box on a Dell xps. I just bought the latest model and have some issues.
Firstly, there is no sound. This is the output of inxi -Aa
Device-1: Intel vendor: Dell driver: N/A bus-ID: 00:05.0 chip-ID: 8086:465d
class-ID: 0480
Device-2: Intel vendor: Dell driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51cc class-ID: 0401
Sound Server-1: ALSA v: k5.18.16-arch1-1 running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.56 running: yes
Any solutions?
pebcak
August 6, 2022, 8:25am
2
Try loading these modules on at a time, check the output of inxi -aA
to see if they get loaded and the sound works.
For how to load a kernel module manually:
https://wiki.archlinux.org/title/Kernel_modules#Manual_module_handling
Neither seems to change the status of the sound devices.
Used modprobe snd_hda_intel
and modprobe snd_sof_pci_intel_tgl
pebcak
August 6, 2022, 8:34am
4
How about this one:
sudo modprobe sof-audio-pci-intel-tgl
modprobe: FATAL: Module sof-audio-pci-intel-tgl not found in directory /lib/modules/5.18.16-arch1-1
pebcak
August 6, 2022, 9:32am
6
Thanks for giving my suggestions a try!
Please wait for other forum members more experienced on sound and/or kernel module issues to chime in. Good luck with troubleshooting and finding the solution!
Thanks for the suggestions.
axt
August 6, 2022, 12:34pm
8
You should also follow this thread with same Alder Lake SPU in a Dell XPS.
Problem has gone with latest update.
