Last night I was trying to fix badblocks on a hard drive.
Short version is now I can’t boot one of my machines.
As I’m reading
It says to ask for help in forums for manual partitions.
At this point I am here
[liveuser@eos-2020.05.08 ~]$ sudo fdisk -l
Disk /dev/sda: 931.53 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: WDC WD10EURX-73F
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: 48E134F1-0042-11E2-8159-0050FC4B5D08
Device Start End Sectors Size Type
/dev/sda1 40 1953525127 1953525088 931.5G Linux filesystem
Disk /dev/sdb: 465.78 GiB, 500107862016 bytes, 976773168 sectors
Disk model: TOSHIBA MQ01ABD0
Disklabel type: gpt
Disk identifier: CACF6CA8-F888-4A43-A991-C63136FF27EB
/dev/sdb1 2048 1026047 1024000 500M Linux filesystem
/dev/sdb2 1026048 205826047 204800000 97.7G Linux filesystem
/dev/sdb3 205826048 211970047 6144000 3G Linux filesystem
/dev/sdb4 211970048 976773119 764803072 364.7G Linux filesystem
Disk /dev/sdc: 931.53 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: Hitachi HDS72101
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 989378E0-17BF-11E1-812D-0050FC4B5D08
/dev/sdc1 34 1953525134 1953525101 931.5G Linux filesystem
Disk /dev/sdd: 1.84 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: SAMSUNG HD204UI
Disklabel type: gpt
Disk identifier: 29363758-0AC8-11E0-B26C-0050FC4B5D08
/dev/sdd1 2048 3907028991 3907026944 1.8T Linux filesystem
Disk /dev/sdf: 1.84 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: WDC WD2002FYPS-1
Disklabel type: gpt
Disk identifier: 905A9BFD-6CE6-11E8-B198-0025222805C7
/dev/sdf1 40 3907029127 3907029088 1.8T FreeBSD UFS
Disk /dev/sdg: 2.75 TiB, 3000592982016 bytes, 5860533168 sectors
Disk model: ST3000DM001-9YN1
Disklabel type: gpt
Disk identifier: 5BC445A5-6C70-11E8-ACA0-0025222805C7
/dev/sdg1 40 5860533119 5860533080 2.7T FreeBSD UFS
Disk /dev/sdh: 3.74 GiB, 4000317440 bytes, 7813120 sectors
Disk model: Cruzer
Disklabel type: dos
Disk identifier: 0x561d0d2e
Device Boot Start End Sectors Size Id Type
/dev/sdh1 * 0 3593919 3593920 1.7G 0 Empty
/dev/sdh2 164 131235 131072 64M ef EFI (FAT-12/16/32)
Disk /dev/loop0: 1.63 GiB, 1730863104 bytes, 3380592 sectors
Disk /dev/sde: 1.84 TiB, 2000398934016 bytes, 3907029168 sectors
Disklabel type: dos
Disk identifier: 0x1ddd54ff
/dev/sde1 2048 3907028991 3907026944 1.8T 83 Linux
Before I screw something up, I thought it best to ask.
In the live boot my boot order is listed as
sdb1 is boot
sdb2 is root
sdb3 is swap
sdb4 is home
The original boot error I got was
dependency failed local files system
If someone could help with the correct procedure in getting me to boot, thankyou.
