[SOLVED] Issue Updating: phonon-qt6-mpv orphaned/unmaintained
I got this this morning when checking for updates…
❯ up
[sudo] password for wombat:
 endeavouros                          15.4 KiB   113 KiB/s 00:00 [------------------------------------] 100%
 core                                116.3 KiB   428 KiB/s 00:00 [------------------------------------] 100%
 extra                                 7.8 MiB  18.2 MiB/s 00:00 [------------------------------------] 100%
 multilib                            134.1 KiB   506 KiB/s 00:00 [------------------------------------] 100%
:: Searching AUR for updates...
:: Searching databases for updates...
 -> Orphan (unmaintained) AUR Packages: phonon-qt6-mpv
 -> Flagged Out Of Date AUR Packages: megasync-bin
 there is nothing to do
Looking for updates…
Nothing to do.
Nothing unused to uninstall
So I thought I’d see what happens if I try to remove it…
❯ yay -Rns phonon-qt6-mpv
checking dependencies...
:: removing phonon-qt6-mpv breaks dependency 'phonon-qt6-backend' required by phonon-qt6
 -> exit status 1
Any ideas/suggestions?
Switch to phonon-qt6-vlc. That’s the officially maintained package from KDE.
That was going to be my first suggestion. Alternatively there’s the maintained phonon-qt6-mpv-git in the AUR.
Perfect. Thanks, @Schlaefer. That did it.
Ran yay -S phonon-qt6-vlc then yay -Rns phonon-qt6-mpv. All is well.
Won’t installing phonon-qt6-vlc install VLC? The reason I installed phonon-qt6-mpv was so I could uninstall the VLC package in the first place.
I just ran yay -R phonon-qt6-mpv?
Yes it is a dependency, but you don’t have to use it (and it does some things that mpv can’t).
Had the same problem, glad I ran into this post. Fresh install from a week ago so I have no clue how this happened.
A week ago, that package was in the repos and has since been dropped.
There is also a pinned post on this topic:
Thank you. New here, but also new to this type of forum software. I did not have VLC installed but I don’t mind it either.
Thanks again.
