The 1st time I did the search I copy/pasted xircon’s command.
After what you said I ran the command again, this time with “Librewolf”, and the output is exactly the same.
The -i
means ignore case. fd is just faster and the syntax is way easier, but there are many ways to skin a cat
There are also desktop entries in $HOME/.gnome/apps
, although most (if not all) are dupes of $HOME/.local/share/applications
A search inside files might find something:
grep -sir "appimage\|librewolf" "$HOME"
Let this run, as it may take long.
You could add some filters for exclusion of irrelevant file types, but it will only save time.
(man grep
ripgrep
is faster and might be a better solution here
So, the find was case insensitive, therefore writing Librewolf or librewolf would not make a difference, right?
Ripgrep required regex, which I have no knowledge of.
Will try it.
Or you could install menulibre.
what does that do?
Reads all menu-entries and lets you edit them.
And what do you think re
in grep
stands for? Regular Expression.
It’s the same thing, only Ripgrep is a bit faster and has more features. But the normal grep
will do just fine, too.
Just do what @petsam suggested, and post the output here.
That is not obvious to a non-regex expert, sorry
Anyhow, @petsam’s command took 1-2 mins. to run, but the output is long, so I have attached a file here.
It is in .odt
format as .txt
format is not accepted.
librewolf-appimage-icon-search.odt (708.0 KB)
I did look through it but did not find anything that suggests phantom icons.
I did, but there was nothing indicating the phantom icons.
Looks like you installed two LW versions from the AUR:
/home/peter/.bash_history:git clone https://aur.archlinux.org/librewolf.git
/home/peter/.bash_history:cd ~/peter/librewolf
/home/peter/.bash_history:cd ~/librewolf
/home/peter/.bash_history:yay -S aur/librewolf
/home/peter/.bash_history:yay -S librewolf
/home/peter/.bash_history:yay -S librewolf-bin
/home/peter/.bash_history:yay -Rs librewolf-bin
I had a botched installation of Librewolf from the AUR, then, following Kresimir’s recommendation I installed librewolf-bin. He also said that if the 2 versions are in conflict, librewolf-bin would remove the other one.
Now, the botched was probably installed to some extent and was therefore not removed. So, should I try yay -Rs librewolf
, or will that mess up the librewolf-bin installation?
It will just return an error, since the package librewolf
is not installed, so there is nothing to remove.
Run
pacman -Qs librewolf
to see which LibreWolf-related packages are installed. If everything is correct, the output should be just this (if you have some extensions from the AUR installed, they might be listed, too, that’s fine):
local/librewolf-bin 102.0.1-1
Community-maintained fork of Firefox, focused on privacy, security and freedom.
Yes, that is exactly what I got as output.
Then you’re fine, no need to install or remove anything.
Regarding the menu entry, I really don’t know why you can’t remove it. I don’t use Cinnamon so I can’t be of help here, unfortunately.
Normally, application launchers populate their menus by looking at .desktop
files in .local/share/applications/
and /usr/share/applications
… So the normal thing to check would be for any superfluous .desktop
file. But if you have ruled that out, I’m out of ideas.
I ran Stacer, and that seems to have done the trick.
