On a friends new machine with AMD renoir and rtl8168 I have just done a fresh installation from the latest ISO. Strangely I had to enable the Lightdm service in order to get a graphical system going once installed. Then I found that the network service was also not enabled. I got all that running, and internet enabled, and yay can update and install stuff, but now relector-simple just keeps returning “no mirrors found”. @manuel ?
You may need to adjust settings in the reflectror-simple window. Default settings (especially Max hours from latest mirror sync) may be too tight in your case?
Or add more countires?
Thanks, it was max hours; set to 10, and it worked with Worldwide and Australia and New Zealand then.
