Hello everyone,
I’m looking to move to Endeavour from Manjaro, but I’ve run into a bizarre issue with my audio interface.
I already am unable to use it for simultaneous input and output and so usually use it as an input for my microphone, but whenever I set it as an audio input my entire system grinds to a halt, sometimes i can still move my cursor and other times I can’t. TTY doesn’t work either.
I’ve tried to look in journalctl but the only thing I can find that is noteworthy is this
Feb 07 20:52:17 hitcoder-endeavour kernel: usb 1-7: Incompatible EP setup for 0x82
This line gets repeated over and over again both whenever I unplug and re-plug the audio interface, and whenever the input device is initialised. There’s no other info there
I’d also like to note that I’ve tried plugging the device into multiple other USB ports.
I’d do more diagnostics on my own end but I’m not really sure what.
My audio interface is a Focusrite Saffire 6 USB, and it’s the usb 1.1 version. I’d just upgrade to something newer but decent audio interfaces are kinda pricy.
I’ve not run into this issue on Manjaro before, and it’s not an issue at all on Windows.
Any help would be appreciated.
EDIT:
relevant dmesg output
[ 3.830033] usb 1-7: new full-speed USB device number 3 using xhci_hcd
[ 4.123720] usb 1-7: New USB device found, idVendor=1235, idProduct=0010, bcdDevice= 1.00
[ 4.123723] usb 1-7: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.123725] usb 1-7: Product: Saffire 6USB
[ 4.123726] usb 1-7: Manufacturer: Focusrite Audio Engineering
[ 27.050620] usb 1-7: Incompatible EP setup for 0x82
[ 27.050636] usb 1-7: Incompatible EP setup for 0x82
[ 27.050643] usb 1-7: Incompatible EP setup for 0x82
[ 27.050650] usb 1-7: Incompatible EP setup for 0x82
[ 27.050657] usb 1-7: Incompatible EP setup for 0x82
[ 27.050788] usb 1-7: Incompatible EP setup for 0x82
[ 27.050796] usb 1-7: Incompatible EP setup for 0x82
[ 27.050803] usb 1-7: Incompatible EP setup for 0x82
[ 27.050809] usb 1-7: Incompatible EP setup for 0x82
[ 27.050816] usb 1-7: Incompatible EP setup for 0x82
[ 27.050974] usb 1-7: Incompatible EP setup for 0x82
[ 27.050995] usb 1-7: Incompatible EP setup for 0x82
[ 27.051014] usb 1-7: Incompatible EP setup for 0x82
[ 27.051032] usb 1-7: Incompatible EP setup for 0x82
[ 27.051050] usb 1-7: Incompatible EP setup for 0x82
[ 27.051258] usb 1-7: Incompatible EP setup for 0x82
[ 27.051289] usb 1-7: Incompatible EP setup for 0x82
[ 27.051317] usb 1-7: Incompatible EP setup for 0x82
[ 27.051345] usb 1-7: Incompatible EP setup for 0x82
[ 27.051372] usb 1-7: Incompatible EP setup for 0x82
[ 27.051549] usb 1-7: Incompatible EP setup for 0x82
[ 27.051558] usb 1-7: Incompatible EP setup for 0x82
[ 27.051564] usb 1-7: Incompatible EP setup for 0x82
[ 27.051570] usb 1-7: Incompatible EP setup for 0x82
[ 27.051577] usb 1-7: Incompatible EP setup for 0x82
[ 27.051734] usb 1-7: Incompatible EP setup for 0x82
[ 27.051743] usb 1-7: Incompatible EP setup for 0x82
[ 27.051749] usb 1-7: Incompatible EP setup for 0x82
[ 27.051755] usb 1-7: Incompatible EP setup for 0x82
[ 27.051761] usb 1-7: Incompatible EP setup for 0x82
[ 27.051948] usb 1-7: Incompatible EP setup for 0x82
[ 27.051971] usb 1-7: Incompatible EP setup for 0x82
[ 27.051989] usb 1-7: Incompatible EP setup for 0x82
[ 27.052007] usb 1-7: Incompatible EP setup for 0x82
[ 27.052025] usb 1-7: Incompatible EP setup for 0x82
[ 27.052266] usb 1-7: Incompatible EP setup for 0x82
[ 27.052296] usb 1-7: Incompatible EP setup for 0x82
[ 27.052324] usb 1-7: Incompatible EP setup for 0x82
[ 27.052351] usb 1-7: Incompatible EP setup for 0x82
[ 27.052378] usb 1-7: Incompatible EP setup for 0x82
I’m gonna try messing with the sample rate I guess.
EDIT2: unfortunately i’m at a loss
EDIT3: I would also like to add that I did try installing pulse audio to replace pipewire, but I had the exact same issues. I’m gonna go to bed now, if there’s any more info you’d like me to grab for you please let me know ASAP. I really want to get this working.
not sure but maybe these pages might be noteworthy? https://linuxmusicians.com/viewtopic.php?t=21426 https://bbs.archlinux.org/viewtopic.php?id=219131
