(SOLVED) External command finished with errors (Installation Failed)
I was wondering if it is working since you installed EndeavourOS?
Yes.
The wifi is working just fine!
I was just checking because you have the Ralink RT3090 Wireless 802.11n 1T/1R PCIe driver: rt2800pci and for some it has been problematic for them. Looks like yours may be newer hardware as i see it is PCI-e and using the correct module rt2800pci.
