am unable to run the dwm desktop on KDE plasma environment of endeavourOs (arch based linux distro) even after following all the procedures of downloading the packages and installing them {dwm, st, dmenu}
i also made the desktop entry in the path /usr/share/xsessions/dwm.desktop and added the script:
[Desktop Entry]
Encoding=UTF-8
Name=DWM
Comment=The Dynamic Window manager
Exec=/usr/local/bin/dwm
Type=XSession
Then i modified the .xinitrc file and added “exec dwm” to the file. Then i have also added the command “startx” at the end of .bash_profile
so now the desktop entry are shown during the login.
But when i try to choose the DWM option and try to login, the dmenu shows up but nothing else will work.
So can anyone please help me out with this problem.
On DWM it is mostly recommended to build it manually… also AUR provides PKGBUILD ready to use…
I do not see that you are running DWM together with plasma… like replacing WM on plasma with DWM? and you try to start DWM standalone while plasma is installed already?
If you use the AUR build it should give you a desktop entry already:
What would give you an entry to start DWM with your DM (SDDM).
Freezing means in your case it really freezes or it is simply not configured? As per default, any WM is mostly an empty space without any configuration: https://dwm.suckless.org/tutorial/
hello Joekamprad , Thanks for the help. Am i suppose to install the aur pkgbuild , on root level(“sudo makepkg -si”) or just the user level pkgbuild is ok ?(“makepkg -si”)
The issue with helping you is the problem is not clear to the community.
Are you trying to run dwm inside KDE? or are you trying to run dwm as a separate desktop environment?
We know, you’re here .
From where did you followed the steps? it would be better if you link or show those to the community.
If you are able to log in after choosing dwm from the SDDM log-in screen that means you can use dwm. And you know dwm is a windows manager not a desktop environment like KDE, GNOME, or XFCE.
As @Zircon34 said if you see a full-screen terminal after pressing the key combo that means your dwm is working.
Thanks for the help @Zircon34 made it clear. and dwm is now working it was my mistake. i thought my dwm was frozen but in actual it was not. when i followed @Zircon34 instruction it was clear.
