[SOLVED] During system upgrade is it normal to get messages like "dracut: dracut module `x` will not be installed, because command `x` could not be found"?
This is the second time i am getting this kind of messages, although i’ve never encounter any issue after the upgrade just curious to know is it normal? Will be there any issue in future?
Here is the screenshot i took recently:
Yes. Totally normal.
It is telling you that things you don’t have installed on your system will not be added to your boot image.
If those messages bother you they can be disabled in the config but that won’t actually change anything, it will just hide the output.
