I am trying to install Makehuman from the AUR, but I am getting the following error:
File “/usr/lib/python2.7/ftplib.py”, line 226, in getresp
raise error_perm, resp
ftplib.error_perm: 550 I can only retrieve regular files
check that download_assets.py is working correctly
Error: errors were encountered during the build. Abort
Error making: makehuman
How can I solve this ?
Last Updated: 2018-11-10 11:57
do you try git version already?
https://aur.archlinux.org/packages/makehuman-git/
Last Updated: 2019-01-05 23:31
I will try that one, but it took almost one hour to build it before the error occured, so dunnow if the git also takes that long.
Edit: Yes, that worked, but did not made a menu entry in Whiskermenu in XFCE.
Edit2: I managed to create menu entry manually
So conclusion is that makehuman-git should be choosen instead of makehuman.
