Solution: Duplicate icons in tint2 system tray
If you find duplicate icons in the Openbox tint2 system tray, dex and systemd may be the culprits. Each may be starting a separate process leading to duplicates. If dex is started via the Openbox autostart script then comment it out and rely on systemd only to start needed processes.
See:
and
Before:
tint2_tray
After:
tint2_systemd_only
If you have duplicate icons - then you have duplicate launchers.
Take a look in ~/.config/autostart and ~/.config/openbox/autostart
