I have a Samsung Galaxy Book3 Pro 360 and up until today, there was a workaround to get audio working. I still had the same issue then but now with it installing some fix when booting I would like to try and figure out the other half of the audio. I have followed all the instructions on the following links and still seem to have the issue. Balance is set at 100% even so that’s not the issue. The left side audio works good, still lacking in slight volume compared to windows but it is livable. Right side even with the volume at 150% is so low you can only hear the test with ear right against speaker.
lspci -kvv
00:1f.3 Multimedia audio controller: Intel Corporation Device 51ca (rev 01)
DeviceName: Onboard - Sound
Subsystem: Samsung Electronics Co Ltd Device c1ca
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 32, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 205
IOMMU group: 15
Region 0: Memory at 603e1d0000 (64-bit, non-prefetchable) [size=16K]
Region 4: Memory at 603e000000 (64-bit, non-prefetchable) [size=1M]
Capabilities:
Kernel driver in use: sof-audio-pci-intel-tgl
Kernel modules: snd_hda_intel, snd_sof_pci_intel_tgl
uname -a
Linux zeus 6.4.6-arch1-1 #1 SMP PREEMPT_DYNAMIC Mon, 24 Jul 2023 20:19:38 +0000 x86_64 GNU/Linux
The only time I’ve had one side of speaker work is when I would accidentally change the balance to be only on one side or the other speaker was broken. I doubt your problem is so simple though. I had looked at a galaxy book in the past, but didn’t really trust samsung to make something linux compatible in the first place. Hope someone knows what’s up though and can help you.
Yeah, i checked the balance. It seems that the verbs are still an issue so was hoping that someone knew something about the fact only half of them would be loading.
