I have snapper installed but no snap-pac. My understanding is that when having installed snap-pac there are pacman hooks so that one has two system snapshots when pacman runs. One before pacman does something and one after pacman has finished its action.
But for the hourly snapshots there are also 2 snapshots which I don’t really want to have, especially when snapshotting for example /home.
snapper supports both cron jobs and systemd timers to run it’s scheduled jobs. Generally you only want one of those running. It has been so many years now since I have run a cron I often forget that some people still install one.
If you are running the cron jobs, you should disable the timers
Wouldn’t it be better to make the cron functionality optional during the installation in Calamares, so that you don’t have to uninstall cronie after the installation (as I do)? That would be more in line with OpenSUSE …
Sorry, dann habe ich da wohl was mit einer früheren Installation verwechselt. Damals (muss schon Jahre her sein), hatte ich wohl auch noch Timeshift installiert. Womöglich kam das daher. Ok, sorry nochmal, alles gut.
