Snap KDE Framework Prerequisite Issue
Hello all! Here is my system
[jeff@gabriel snapd]$ inxi -FAZ
  Host: gabriel Kernel: 6.4.1-arch1-1 arch: x86_64 bits: 64
    Desktop: KDE Plasma v: 5.27.6 Distro: EndeavourOS
  Type: Desktop Mobo: Micro-Star model: MAG Z490 TOMAHAWK (MS-7C80) v: 1.0
    serial: <superuser required> UEFI: American Megatrends v: 1.C0
    date: 06/11/2022
  Info: 8-core model: Intel Core i7-10700K bits: 64 type: MT MCP cache:
    L2: 2 MiB
  Speed (MHz): avg: 3244 min/max: 800/5100 cores: 1: 800 2: 3800 3: 3800
    4: 800 5: 3800 6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 910 12: 3800
    13: 3800 14: 3800 15: 3800 16: 3800
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
    driver: amdgpu v: kernel
  Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: amdgpu
    unloaded: modesetting dri: radeonsi gpu: amdgpu resolution: 2560x1080~60Hz
  API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon RX 570 Series
    (polaris10 LLVM 15.0.7 DRM 3.52 6.4.1-arch1-1)
  Device-1: Intel Comet Lake PCH cAVS driver: snd_hda_intel
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
  API: ALSA v: k6.4.1-arch1-1 status: kernel-api
  Server-1: PipeWire v: 0.3.72 status: active
  Device-1: Intel Ethernet I219-V driver: e1000e
  IF: eno1 state: down mac: 2c:f0:5d:8d:52:3d
  Device-2: Realtek RTL8125 2.5GbE driver: r8169
  IF: enp3s0 state: down mac: 2c:f0:5d:8d:52:3e
  Device-3: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi
  IF: wlan0 state: up mac: f4:7b:09:ca:89:dd
Bluetooth:
  Device-1: Realtek driver: btusb type: USB
  Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: disabled
  Local Storage: total: 4.55 TiB used: 7.47 GiB (0.2%)
  ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB
  ID-2: /dev/sda vendor: Seagate model: BUP Fast HDD size: 3.64 TiB
    type: USB
  ID-1: / size: 930.53 GiB used: 7.3 GiB (0.8%) fs: btrfs dev: /dev/nvme0n1p2
  ID-2: /home size: 930.53 GiB used: 7.3 GiB (0.8%) fs: btrfs
    dev: /dev/nvme0n1p2
  ID-3: /var/log size: 930.53 GiB used: 7.3 GiB (0.8%) fs: btrfs
    dev: /dev/nvme0n1p2
  System Temperatures: cpu: 36.0 C pch: 42.0 C mobo: N/A gpu: amdgpu
    temp: 48.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 220
  Processes: 354 Uptime: 39m Memory: available: 15.54 GiB
  used: 2.46 GiB (15.8%) Shell: Bash inxi: 3.3.27
I am rather new to EOS and I am having an issue trying to install a snap package that is useful to me. I get the following error when trying to perform the installation:
[jeff@gabriel ~]$ sudo snap install qelectrotech
[sudo] password for jeff:
error: cannot perform the following tasks:
  • Ensure prerequisites for “qelectrotech” are available (cannot install prerequisite “kde-frameworks-5-qt-5-15-3-core20”: no snap revision available as specified)
What is the correct way to install this requisite and get this snap installed? Thank you!
That seems like an issue with the snap.
Do you need the snap? It seems to be available from the AUR.
No dalto I do not need a snap. I am sorry not to look more comprehensively. I checked a couple of weeks ago but for some reason, I was only able to find the snap :blush: . Thanks man.
