I tried to gather a lot of information relating to my NVMe disks:
[user:~] $ nvme list
Node Generic SN Model Namespace Usage Format FW Rev
/dev/nvme0n1 /dev/ng0n1 2452E99D29EE CT4000T705SSD3 0x1 4.00 TB / 4.00 TB 4 KiB + 0 B PACR5111
/dev/nvme1n1 /dev/ng1n1 24352Z800361 WD_BLACK SN850X HS 8000GB 0x1 8.00 TB / 8.00 TB 4 KiB + 0 B 638201WD
/dev/nvme2n1 /dev/ng2n1 25071N800223 WD_BLACK SN850X HS 8000GB 0x1 8.00 TB / 8.00 TB 4 KiB + 0 B 638211WD
[user:~] 6m5s $ sudo nvme smart-log /dev/nvme0n1
Smart Log for NVME device:nvme0n1 namespace-id:ffffffff
critical_warning : 0
temperature : 36 °C (309 K)
available_spare : 100%
available_spare_threshold : 5%
percentage_used : 0%
endurance group critical warning summary: 0
Data Units Read : 33486003 (17.14 TB)
Data Units Written : 35555777 (18.20 TB)
host_read_commands : 210915118
host_write_commands : 184281717
controller_busy_time : 279
power_cycles : 304
power_on_hours : 2575
unsafe_shutdowns : 98
media_errors : 0
num_err_log_entries : 0
Warning Temperature Time : 0
Critical Composite Temperature Time : 0
Thermal Management T1 Trans Count : 0
Thermal Management T2 Trans Count : 0
Thermal Management T1 Total Time : 0
Thermal Management T2 Total Time : 0
[user:~] $ sudo nvme smart-log /dev/nvme1n1
Smart Log for NVME device:nvme1n1 namespace-id:ffffffff
temperature : 41 °C (314 K)
available_spare_threshold : 10%
Data Units Read : 24078933 (12.33 TB)
Data Units Written : 58749767 (30.08 TB)
host_read_commands : 107076293
host_write_commands : 275873484
controller_busy_time : 343
power_cycles : 363
power_on_hours : 2511
unsafe_shutdowns : 150
media_errors : 0
Temperature Sensor 1 : 51 °C (324 K)
Temperature Sensor 2 : 39 °C (312 K)
Temperature Sensor 3 : 38 °C (311 K)
[user:~] $ sudo nvme smart-log /dev/nvme2n1
Smart Log for NVME device:nvme2n1 namespace-id:ffffffff
temperature : 42 °C (315 K)
Data Units Read : 25668917 (13.14 TB)
Data Units Written : 43482140 (22.26 TB)
host_read_commands : 170380938
host_write_commands : 195614278
controller_busy_time : 254
power_cycles : 183
power_on_hours : 1828
unsafe_shutdowns : 59
media_errors : 0
num_err_log_entries : 1
Temperature Sensor 1 : 52 °C (325 K)
Temperature Sensor 2 : 41 °C (314 K)
Temperature Sensor 3 : 39 °C (312 K)
[user:~] $ sudo nvme fw-log /dev/nvme0n1
Firmware Log for device:nvme0n1
afi : 0x1
frs1 : 0x3131313552434150 (PACR5111)
[user:~] 1 $ sudo nvme fw-log /dev/nvme1n1
Firmware Log for device:nvme1n1
afi : 0x1
frs1 : 0x4457313032383336 (638201WD)
[user:~] $ sudo nvme fw-log /dev/nvme2n1
Firmware Log for device:nvme2n1
afi : 0x1
frs1 : 0x4457313132383336 (638211WD)
[user:~] $ sudo nvme get-feature -f 0x0c -H /dev/nvme0n1
get-feature:0x0c (Autonomous Power State Transition), Current value:0x00000001
Autonomous Power State Transition Enable (APSTE): Enabled
Auto PST Entries .................
Entry[ 0]
Idle Time Prior to Transition (ITPT): 100 ms
Idle Transition Power State (ITPS): 4
Entry[ 1]
Entry[ 2]
Entry[ 3]
Entry[ 4]
Idle Time Prior to Transition (ITPT): 0 ms
Idle Transition Power State (ITPS): 0
Entry[ 5]
Entry[ 6]
Entry[ 7]
Entry[ 8]
Entry[ 9]
Entry[10]
Entry[11]
Entry[12]
Entry[13]
Entry[14]
Entry[15]
Entry[16]
Entry[17]
Entry[18]
Entry[19]
Entry[20]
Entry[21]
Entry[22]
Entry[23]
Entry[24]
Entry[25]
Entry[26]
Entry[27]
Entry[28]
Entry[29]
Entry[30]
Entry[31]
[user:~] 1 $ sudo nvme get-feature -f 0x0c -H /dev/nvme1n1
Entry[ 0]
Idle Time Prior to Transition (ITPT): 2000 ms
Entry[ 1]
Entry[ 2]
Entry[ 3]
Entry[ 4]
Entry[ 5]
Entry[ 6]
Entry[ 7]
Entry[ 8]
Entry[ 9]
Entry[10]
Entry[11]
Entry[12]
Entry[13]
Entry[14]
Entry[15]
Entry[16]
Entry[17]
Entry[18]
Entry[19]
Entry[20]
Entry[21]
Entry[22]
Entry[23]
Entry[24]
Entry[25]
Entry[26]
Entry[27]
Entry[28]
Entry[29]
Entry[30]
Entry[31]
[user:~] $ sudo nvme get-feature -f 0x0c -H /dev/nvme2n1
Entry[ 0]
Entry[ 1]
Entry[ 2]
Entry[ 3]
Entry[ 4]
Entry[ 5]
Entry[ 6]
Entry[ 7]
Entry[ 8]
Entry[ 9]
Entry[10]
Entry[11]
Entry[12]
Entry[13]
Entry[14]
Entry[15]
Entry[16]
Entry[17]
Entry[18]
Entry[19]
Entry[20]
Entry[21]
Entry[22]
Entry[23]
Entry[24]
Entry[25]
Entry[26]
Entry[27]
Entry[28]
Entry[29]
Entry[30]
Entry[31]
[user:~] $ sudo nvme get-feature -f 0x02 -H /dev/nvme0n1
get-feature:0x02 (Power Management), Current value:0x00000040
Workload Hint (WH): 2 - Heavy Sequential Writes
Power State (PS): 0
[user:~] 1 $ sudo nvme get-feature -f 0x02 -H /dev/nvme1n1
get-feature:0x02 (Power Management), Current value:0x00000004
Workload Hint (WH): 0 - No Workload
Power State (PS): 4
[user:~] $ sudo nvme get-feature -f 0x02 -H /dev/nvme2n1
Power State (PS): 4
As you can see both of the WD Black 8TB SN850X have sensors sitting at 51C while idle. The other NVMe drive also has a fairly high idle average temperature, but doesn’t show the direct sensor information. The WD Black drives came with heatsinks attached and are in a well ventilated case, the Crucial T705 uses a heatsink included with the mobo.
I don’t see any heavy I/O in iotop at idle. Under load, the average temperature for the SN850x disks quickly increases to 80C+ and I feel the need to stop so it can cool down. Copies are FAST but I’m worried I’m going to cook my storage like this.
The two SN850X 8TB NVMe disks are formatted into a LVM containing LUKS2 encrypted ext4 partitions.
I tried following some advice online and checked for interrupts, and found one that I masked. But it didn’t have much impact as far as I could see:
grep -Ev "^[ ]*0" /sys/firmware/acpi/interrupts/gpe?? | sort --field-separator=: --key=2 --numeric --reverse | head -1
/sys/firmware/acpi/interrupts/gpe1B: 1 enabled masked
I also found this which sounded similar to my issue, so I tried adding nobarrier for the drive’s partitions in fstab, but it did not help either:
Feeling way out of my depth here, please help ![]()
