SMART health of SSD's
So I have multiple drives. Most are at 5 or 10%, none higher than 10%.
One is at 1%.
Half of these drives have never had an operating system on them, just used for storage including the one with 1% (4TB PNY, half full/used).
All say… SMART overall-health self-assessment test result: PASSED.
Are we sure about the “Available Spare” % showing a chance of drive failure is greater with a lower % ?
Purchase dates for the drives…
2TB - Mushkin x 2 - Dec. 2020
2TB - PNY - Jun 2023
4TB - PNY - x 2 - Jul 2023
2TB - Silicon Power - Apr 2024
2TB - WD Black - Aug 2024
2TB - Crucial - Jun 2025
2TB - Fanxiang - Dec 2026
That is really wierd, specially if they are only used the way you say. Maybe check them with another tool just be safe.
The only Nvme that I owned that failed also didn’t gave any signal of failure and yet it died.
These sudden drive deaths are the reason why I still have all my server storage units running on HD instead SSDs/Nvme.
To my knowledge Available Spare Threshold is just the level at which it will warn. Not the current value. Available Spare is at 100% so all the spares are available at the moment and not used. This is a mfg set value for the disk. On the other hand, Percentage Used is one of the most important value here as it really indicate the current wear of the disk.
I went back and checked that and none of my drives show higher than 4 Percentage Used…
0% - 3 drives
1% - 2 drives
3% - 2 drives
4% - 2 drives
Now that I’m home, I have to say those numbers seem very unusual, particularly across multiple SSDs from different manufacturers.
Are you sure you’re looking at Available Spare rather than Available Spare Threshold or Percentage Used?
These are three distinct SMART attributes.
If your PNY SSD really reports Available Spare: 1% with a threshold of 10%, that should normally trigger an NVMe critical warning, so the PASSED health status would be worth investigating.
Got the same numbers using nvme-cli.
Here’s a typical output…
Available Spare: 100%
Available Spare Threshold: 5%
Percentage Used: 1%
I have noted some SMART inconsistencies between different manufacturers in the past, where some might invert the result, or use a different unit for different measurements. It can be quite confusing.
Well, that makes more sense now. Your drives are in mint condition.
Those values you shared before were the Available Spare Threshold.
Ah Ok, got it now. What does the “Threshold” measure?
Think of an SSD as having extra memory cells held in reserve to replace cells that wear out or become defective over time.
Available Spare: The percentage of the drive’s normalized reserve capacity that is still available. At 100%, the reserve is fully available. As this percentage decreases, the drive has fewer spare cells to replace worn-out ones.
Spare Wear: This isn’t a standard NVMe SMART attribute. It generally refers to reserve capacity being used up as memory cells wear out or fail.
Available Spare Threshold: The minimum acceptable spare percentage set by the manufacturer. For example, if the threshold is 10%, the drive should issue a warning when its available spare drops below that limit.
I hope this explains it in a simple, clear way :sweat_smile:
Ah making more sense to me now, thx for clearing a lot of that up for me! :+1:
Next up, error messages that say a bunch of jibberish to me anyway, and then at the end state "“no errors” . :upside_down_face:
I just checked error log entries for one drive using nvme-cli. Most of the drives don’t show any errors. I didn’t include all 60 plus of the entries as they all say pretty much the same thing except the first one…
This is first drive I bought and installed Mint on 6 years ago.
user101@Q4Machina:~$ sudo nvme error-log /dev/nvme0n1
Error Log Entries for device:nvme0n1 entries:63
 Entry[ 0]
error_count     : 4995
sqid            : 0
cmdid           : 0xc009
status_field    : 0x2002 (Invalid Field in Command: A reserved coded value or an unsupported value in a defined field)
phase_tag       : 0
parm_err_loc    : 0x28
lba             : 0
nsid            : 0x1
vs              : 0
trtype          : 0 (The transport type is not indicated or the error is not transport related)
csi             : 0
opcode          : 0
cs              : 0
trtype_spec_info: 0
log_page_version: 0
 Entry[ 1]
error_count     : 0
sqid            : 0
cmdid           : 0
status_field    : 0 (Successful Completion: The command completed without error)
phase_tag       : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
csi             : 0
opcode          : 0
cs              : 0
trtype_spec_info: 0
log_page_version: 0
 Entry[ 2]
error_count     : 0
sqid            : 0
cmdid           : 0
phase_tag       : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
csi             : 0
opcode          : 0
cs              : 0
trtype_spec_info: 0
log_page_version: 0
 Entry[ 3]
error_count     : 0
sqid            : 0
cmdid           : 0
phase_tag       : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
csi             : 0
opcode          : 0
cs              : 0
trtype_spec_info: 0
log_page_version: 0
 Entry[ 4]
error_count     : 0
sqid            : 0
cmdid           : 0
phase_tag       : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
csi             : 0
opcode          : 0
cs              : 0
trtype_spec_info: 0
log_page_version: 0
 Entry[ 5]
error_count     : 0
sqid            : 0
cmdid           : 0
phase_tag       : 0
parm_err_loc    : 0
lba             : 0
nsid            : 0
vs              : 0
csi             : 0
opcode          : 0
cs              : 0
trtype_spec_info: 0
log_page_version: 0
Moved your discussion to a dedicated topic @jackkileen :+1:
Don’t worry about it.
Just ignore it!!
If your SSD is functioning normally and SMART health status shows good, you can completely disregard those log entries. They are just noise
Ok thx for all the info on testing these drives! I purchased all these on really good, various discounted sales and trying to replace them these days would cost up to 4-5 times what I originally paid for them.
oh i see now we have a new game :video_game:
Show your .. hardware issues/specs/warnings that’s a nice game to learn and resolve things randomly.
Like aha what does it show on my hardware? oh nice tool.. or ups why it warns about xy ?
From endless tinkering with checking drives and hardware i know that if one tool is showing an issue or wrong value it is often a BUG or wrong detection or even simple wrong tool in case.
