I like to use a vertical monitor as well as a regularly oriented one but I find there’s a small lag in the display of the rotated monitor. Both my monitors are 2560x1440 and I use the proprietary nvidia drivers for my card (gtx 980). Everything displays fine but I would like to know why the lag exists on the vertical monitor. It makes moving the mouse more difficult than the regular monitor because I need to account for the lag. I can easily see the lag when I move a monitor vertically across the span of my two monitors but, interestingly, the lag doesn’t show up when I make a screen recording of the same area - only when I use my desktop regularly. I experience no lag when I have the rotated monitor it oriented regularly in Windows or Linux. Does anyone have any insights into why this is? I don’t experience this on Windows on the same setup.
That last statement shoots down my thought on the matter, that perhaps you were getting an artifact of monitor passthrough problems…
So - we need some more info on your setup before any guesses (troubleshooting) can achieve usefulness! A good place to start is to paste the output of inxi -Faz between lines of triple ` (backticks) so as to be clearly formatted.
Incidentally, I run a vertical secondary monitor as well as horizontal one, at different resolution settings (scaled on the vertical) and have no such lag. I’m on XFCE though, I have no idea what you are using.
Edit: Noticed some data was missing so I installed those packages and reran inxi -Faz.
Edit2: I notice Monitor-2 (the rotated one) doesn’t have the same amount of information present as Monitor-1. Could this be contributing to the problem?
Edit3: Monitor-2 shows all information if it’s oriented regularly:
So, found a couple more things that may help narrow things down. I notice identical lag on both monitors when I have “Force Full Composition Pipeline” set on both. What’s nice is that I no longer have a difference in mouse movement when using one monitor or the other. What isn’t is that now my non-rotated monitor lags as much as the rotated one. I don’t find a difference having “Force Full Composition Pipeline” enabled on the rotated monitor or not - it lags all the same.
I played around with the resolution of my rotated monitor and found no difference in lag even when I lowered its resolution to 720x1280.
Interestingly, all visual lag disappears when I boot KDE into Wayland. Unfortunately, Wayland seems to be buggy for my uses and it was difficult to use.
