Small help with Timeshift
After the my mess today, where I wanted to roll back one day, I noticed that I had only one snapshot from over a week ago (when I set it up). It seems like Timeshift just doesn’t take any snapshots for me (like I intended to).
This seems very similar to this post Timeshift-autosnap not working with yay update - #7 by DromundKaas unfortunately there is no solution there.
/etc/timeshift-autosnap.conf
zsh: no such file or directory: /etc/timeshift-autosnap.conf
This here scares me… because I did go through the setup of Timeshift.
IF Timeshift is completely borked, what program do you recommend instead?
What says
pacman -Q timeshift-autosnap
Edit:
Just adding that the settings for timeshift is stored at /etc/timeshift/default.json
Here you go
error: package 'timeshift-autosnap' was not found
And the default.json says
backup_device_uuid	""
parent_device_uuid	""
do_first_run	"true"
btrfs_mode	"false"
include_btrfs_home	"false"
stop_cron_emails	"true"
schedule_monthly	"false"
schedule_weekly	"false"
schedule_daily	"false"
schedule_hourly	"false"
schedule_boot	"false"
count_monthly	"2"
count_weekly	"3"
count_daily	"5"
count_hourly	"6"
count_boot	"5"
snapshot_size	"0"
snapshot_count	"0"
exclude	[]
exclude-apps	[]
Will change daily to “true” and I prefer to have 3 snapshots stored.
I guess we’ll see tomorrow night to see if the change stuck or not.
You don’t have timeshift-autosnap installed.
It is an AUR package providing a hook which triggers a timeshift’s snapshot to be taken prior to package upgrades.
:eye: https://aur.archlinux.org/packages/timeshift-autosnap
Also, if you set timeshift to be run on schedule, make sure to have enabled and started cronie.service:
sudo systemctl enable --now cronie.service
Thank you for this.
Just my curiosity, do I need the timeshift-autosnap? I thought it was enough to have just scheduled service.
Did not know about the cronie.service so thank you for that.
It is not a must. It is totally up to you.
If you are going to take several snapshots daily and are not a “heavy tweaker” making changes to your system all the time, I would say you will have relatively fresh snapshots to roll back to if/when the need arises.
I have “tweaked” as much as I want. I think one per day should suffice.
Thank you for this.
I want to see if enabling cronie.service fixes my problem. So if I see a new snapshot tomorrow, I’ll mark this as solved :slight_smile:
Have you already set up Timeshift?
You could do it using the GUI. No need to edit the file directly.
And good luck!
That’s the thing, I had already set up Timeshift, but I got no snapshot. I did that over a week ago and the only snapshot I have, is the one I made.
I did the setup through the GUI, but like the file said, everything was set to “false”.
I guess that was because Timeshift relies on cronie.service to run on schedule.
Check the status of the service:
systemctl status cronie.service
If it is running so hopefully Timeshift will “behave” as it should.
It’s running. Just want to see new snapshot tomorrow before I mark this as resolved :slight_smile:
