Slow usb speeds
I have been having an issue for a while now, and decided to come here for help.
I cannot figure out why usb speeds slow to a crawl. I was trying to download Snappy Driver Origin (to get driverpacks to install on a windows machine that is offline) which I have used for probably 2 decades and it is a 40~GB download. When transferring it to the usb drive, the transfer drops to an abysmal <1Mbps transfer speed. Doesnt matter if its 2.0 or 3.0 usb devices or ports.
I have seen this before, MANY times. Thats why Im asking here. I asked once on Manjaro, and lets just say they removed my solution… :melting_face: (I just used windows as I was dual booting at the time, it was a 200GB hard drive copy I was moving via usb)
link to it:https://forum.manjaro.org/t/slow-usb-transfers/146863
I’m not bashing manjaro, they did try to help. This issue crops up on every major distro I’ve come across. Doesnt matter the hardware, or the usb drive whether is flash or HDD. They couldn’t replicate the issue, and somehow also did not have any similar equipment to test with. (2.0 or 3.0 usb flash/HDD drives)
When I say slow, I mean hours for a few GBs to actual days if its a few more GBs. I’ve searched elsewhere on google, it pops up everywhere and no one can find the answer. There is a linux mint post here:https://forums.linuxmint.com/viewtopic.php?t=387874 They eventually decide its not a linux issue but busted hardware, despite the user clearing the tests–they do hint that it -may- be a bug in the kernel, which I also suggested in my manjaro forum post. It gets repeated as far back as 2014 on ubuntu forums, so the issue is not new.
THE TEST: Transfer a large amount of data to a usb drive. Doesn’t matter if its a flash or HDD drive. It’s not a cache issue or a “reporting the wrong speed issue” or a thermal issue. My 40GBs of data ran for 5 hours before I unmounted the drive, to find it had wrote about 6GB. Just 6. Its not thousands of small files either, just a few that a 1-3GB in size.
Can anyone else replicate this? I am a newbie when it comes to linux, but i’ve had this problem off and on for as far back as I can remember.
Edit: forgot to mention it seems to occur after 30 seconds to a minute or two of transferring. Sorry for the blogpost but I had to add some backstory. :slight_smile:
Please provide output of inxi -Fzxxx with all relevant USB devices attached.
No I can not. I am using usb devices as my backup and I frequently transfer GB / TB of data via USB without any performance issue.
Having done fairly large transfers to USB drives on Linux, this isn’t a problem of Linux, but more likely a problem of specific hardware, at least from my experiences in the past.
That isn’t to say that it’s impossible that the current kernels might not have a problem, but they worked fine back in the 5. and early 6. eras.
A lot more information is needed. I mean first What DE is this happening in? How are you doing the copy? What other processes are running at the time? What filesystem?
I regually copy large files between the computer and USB thumb drives and hard drives. While the speed is always faster going to another hard drive the thumb drives can take much longer to write.
When ever I copy large files I go straight to the command line. Doing it this way for years and never an issue. Much less on the resources and its faster.
If copying from a Linux Device to a NTFS device can take quite a long time itself. I think this is more because of the way Microsoft does things vs the way linux does things (data storage).
It has spanned back for over a decade that i can recall. Thats the problem, unless someone can see it for themselves its impossible to diagnose.
Any DE, though I mostly use KDE. Copy method doesnt seem to matter, happens in dolphin file manager or through terminal with copy command. What ever other processes exist during runtime, I can’t possibly list that. As far as filesystems go, this is one that seems it might have something to do with it (as a lot of people immediately jump on the NTFS/windows hate wagon,) but it doesnt seem to matter what filesystem. I’ve tried dozens of variables, ext3-4, ntfs, exfat, etc on usb 2.0 and 3.0, flash drive or HDD, to the same avail. Works at first, followed by slowdown, followed by a crawl.
The only OS i tested that worked was FerenOS, and that test even spanned multiple machines both desktop and laptop (from 2009ish to a 2022 dell laptop) I have been thorough doing tests like this before, the problem is getting someone with more knowledge than me to investigate it with similar hardware. The current two pc’s im having an issue with are a ryzen 1800x with x370 asrock board and an ancient inspiron 560 with a broke ethernet adapter. I tried 4 different 128GB 3.0 sticks and a 3.0 HDD before i finally just opened Snappy drivers using WINE (i love WINE :smiley: ) and downloaded the drivers into a folder and shared the folder over a network, which worked fine of course. Hilariously enough, using a usb to ethernet adapter.. so once again im not sure why the problem affects drives and not a usb to ethernet adapter which functioned up to a continuous 8MBps (100Mbps) which took about a reasonable hour.
I first noticed the issue when creating live iso files on usb drives using linux. I had a 4GB flash drive that i regularly reinstalled windows with, and knew it took a solid 20 minutes to copy over to the drive. But when using linux as a daily driver on another pc, I could never get it to copy and would just pull the drive and reformat it in frustration and use another windows pc to make the live iso again. That was 10 years ago at least, I remember slipstreaming drivers onto the windows iso lol as it wouldnt boot via usb.
Anyone? Please post results. I’m still curious who has this bug…
I’m resurrecting this post because it hit me again.:frowning:
I was in the middle of a nightmare situation thinking my pc had begun to kick the bucket, and decided to reformat a usb drive with ventoy on it so that i knew the data wasnt corrupted, and once again hit this slow usb speed issue. I copied over EndeavourOS’s iso file and a few others (archcraft, manjaro, xubuntu, and a couple of necessary boot/repair iso’s) for a collection of about 35GB, and it took about 7 hours to transfer. I actually used the corrupted pc in that forum post initially, but after about an hour thought it would be better to use a more trustworthy machine (a spare laptop I have) based on the circumstances. I went to town and did a few errands and got food, only to come back to see it still transferring.
I’m not sure if i made this clear in the original post (i didn’t reread it since i posted it a while back) but the first few GB’s transfer perfectly fine at the correct speeds. It drops MASSIVELY in speed after that, all the way down to a few hundred kilobytes per second, and the time it takes to complete the entire transfer backs up such speed reports like those listed in KDE’s system tray. It goes up and down at times, but it stays in the 0.5-2MB range, even with usb 3.0 hardware. The most interesting part of this is if you transfer large files, but one at a time (say no more than 1.5GB) they transfer fine and at the correct speed and is easily verified by actually running the iso files or hashing them. The same 35GB of files will transfer in prob about 30-40 minutes depending on how fast you are at copy/pasting the files. It’s not specific to arch either, that transfer was done on a xubuntu install.
The transfer was done with mechanical HDD to usb 3.0 flash drive via a blue 3.0 port, on both computers. Both took hours, and i would’ve done the “small and fast” method but some of those iso files are >5GB.
No light to shed, I can say that I burned a 7 GB ISO this past week and it took (guestimate) 20 minutes to dd. Seemed like it took longer to use dd than to use Ventoy, but that was probably my imagination and impatience.
I am contemplating recording a video of it happening, im just not sure how. screen recording is new territory for me
what is the results of
inxi -Faz --no-host
I copy Gigs of files over to external devices all the time and the only “slowness” i ever get is when writing to a thumb drive. (a limitation of thumbdrives)
It’s almost certainly harware-related. I’ve seen this any number of times on laptops across the years. You already eliminated USB protocol version as the cause. Things to look at:
HDD characteristics. Drive speed bus type, and bus cache will massively affect transfer rates, especially with files spread out over multiple platters. There is a world of difference between a 5000 rpm and a 7500 rpm HDD.
USB stick itself. Is the USB stick rated for USB 3.0? A 3.0 thumb drive is much faster and has a larger cache. If you’re using a cheap USB 2.0 stick in a USB 3.0 slot on your computer, chances are good you will hit the drive’s cache and overwhelm it. The USB memory speed is also a factor, as is the defect rate. Unsurprisingly, cheap USBs tend to use slower memory, have small caches, and have more defects than higher-quality sticks. Lastly, if the stick has been used a lot, the writes will have degraded the memory over time.
Computer data bus speed and cache. Same comment as above. Bus speed and cache speed will affect data transfers.
EXT4 journaling. It writes changes to the journal before it writes data to a file system.
The symptom of high transfer rate, dropping suddenly down to a crawl, strongly suggests a cache is being overwhelmed. Which cache is the question.
Interesting topic, Usb 1.0 to Usb 3.0 . . . quite a difference in speed and performance especially data transfer. Thumb drives are color coded to fit matching Usb ports for optimal transfer. Blue to Blue, Red to Red . . . speed on the bus is determined by what other factors? Memory buffer? I wouldn’t know.
Rich :slight_smile:
I went through a bit of a research back then as I had a similar issue with thumbdrives, and I suspected my chipset (B550) was to blame. Turns out the thumbdrive was very, very slow, as most of them appear to be.
You say you see the same with HDDs, so your case is probably something else.
You also mentioned you are sure it’s not a caching issue. Do you mean you have already tried the writeback-cache tuning as shown here, for instance?
Nevertheless: I see no mention of the hardware involved. Can you provide the motherboard/laptop model? Also, the types of media you used.
I thought it was CMR to SMR that was causing the problem, then maybe the filesystem types, etc. I already cleared those avenues sadly.
Nah. This is persistent across sticks. I’ve checked to make sure it wasnt a 2.0/3.0 issue. Proper ports and drives.
Works fine under windows, and apparently FerenOS, though when i tested it it was 2 years ago.
Even happens with NTFS to NTFS drives. I tested a few others, I dont remember which now.
True, but a cache wouldnt turn a 30 minute 4gb transfer on 2.0 into a 4-8 hour endeavor, or a 200gb transfer over 3.0 into a few days. Maybe a slowdown, but thats not even a crawl :slight_smile:
I do, the original post at the top that links to my issue when I had manjaro was between HDDs. One was an internal SATA CMR drive if i remember correctly, transferring to a usb 3.0 external HDD. But I did different tests and came across the same issue, whether stick or HDD. I never tested SSDs.
I think i did try that at one point, but it didnt help. One significant difference is I never had the system slow to a crawl or lock up, unlike that article you pointed me to. I’m not sure Ive ever experienced what theyre describing to be honest.
  Kernel: 6.17.8-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    clocksource: tsc avail: hpet,acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-linux
    root=UUID=***************** rw nowatchdog
    nvme_load=YES resume=***************** loglevel=3
  Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
    wm: kwin_wayland vt: 1 dm: SDDM Distro: EndeavourOS base: Arch Linux
  Type: Desktop Mobo: ASRock model: X370 Professional Gaming
    serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends v: P4.60 date: 03/02/2018
  Info: model: AMD Ryzen 7 1800X bits: 64 type: MT MCP arch: Zen level: v3
    note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
    stepping: 1 microcode: 0x8001136
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 threads: 16 tpc: 2
    smt: enabled cache: L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB
    desc: 8x512 KiB L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 3610 high: 3700 min/max: N/A cores: 1: 3600 2: 3600
    3: 3600 4: 3600 5: 3600 6: 3600 7: 3600 8: 3600 9: 3700 10: 3600 11: 3600
    12: 3600 13: 3600 14: 3600 15: 3600 16: 3662 bogomips: 115212
  Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a
    ssse3 svm
  Display: wayland server: X.org v: 1.21.1.20 with: Xwayland v: 24.1.9
    compositor: kwin_wayland driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 3840x1080
    display-ID: 0
  API: EGL v: 1.5 platforms: device: 1 drv: swrast gbm: drv: kms_swrast
    surfaceless: drv: swrast wayland: drv: swrast x11: drv: swrast
    inactive: device-0
  API: OpenGL v: 4.5 vendor: mesa v: 25.2.7-arch1.1 glx-v: 1.4
    direct-render: yes renderer: llvmpipe (LLVM 21.1.5 256 bits)
    device-ID: ffffffff:ffffffff memory: 45.87 GiB unified: yes
    display-ID: :1.0
    de: kscreen-console,kscreen-doctor wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
    470/480 / 570/580/590] vendor: ASUSTeK driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:aaf0
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: ASRock
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 2f:00.3 chip-ID: 1022:1457 class-ID: 0403
  Device-3: C-Media USB Audio Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 0d8c:0012 class-ID: 0300
  API: ALSA v: k6.17.8-arch1-1 status: kernel-api
  Server-1: sndiod v: N/A status: off tools: aucat,midicat,sndioctl
  Server-2: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
  Kernel: swappiness: 0 (default 60) cache-pressure: 100 (default) zswap: yes
    compressor: zstd max-pool: 20%
  ID-1: swap-1 type: partition size: 71.29 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda2 maj-min: 8:2
  System Temperatures: cpu: 45.1 C mobo: N/A gpu: amdgpu temp: 50.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 1047
  Memory: total: 48 GiB available: 46.97 GiB used: 6.07 GiB (12.9%)
  Processes: 411 Power: uptime: 2d 21h 24m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 18.76 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1985 libs: 506 tools: yay
    pm: rpm pkgs: 0 pm: flatpak pkgs: 0 Compilers: clang: 21.1.6 gcc: 15.2.1
    Shell: Bash v: 5.3.3 running-in: konsole inxi: 3.3.39
I skipped some of the probably irrelevent data. The interal drives are standard old seagate HDDs. I dont have access to the pc i used in the manjaro tests, someone bought it.
Thanks for the info. It’s a bit of a long shot but I see you run bios 4.80, which is from 2018. The latest stable is 7.30 from late 2022.
I am generally uncomfortable upgrading the BIOS unless strictly necessary, especially since ASrock does not list any explicit fix to USB… it depends on how much of a risk you’d like to take.
On that topic: have you tried checking with the ASrock support if they heard any report of such issues?
Sure haven’t, I never bothered asking a manufacturer or doing a BIOS upgrade as I’ve had this issue many times before over the years, but never with Windows despite it being the same hardware. I may be upgrading my CPU soon which will require a BIOS upgrade, I will post here if it makes a difference.
I have the same issue with copying files to USB drives. Right now I’m trying to copy 140 files of 170MB to a USB Stick. The first few files would be transferred almost immediately and after that the speed drops and the transfer never finishes. I had it run over night and it was not nearly finished. I tried to cancel the copying but the process seems to continue in the background.
I tried to copy it file for file, but even if it shows as done I cant eject the drive as the KDE drive manager says it is still copying files to that drive.
inxi -Faz --no-host
  Kernel: 6.18.58-1-lts arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
    parameters: initrd=\edf4d6281d4d4426913b3410df33de89\6.18.58-1-lts\initrd
    nvme_load=YES nowatchdog rw
    root=UUID=0fd41213-3221-4221-9471-bed9f0a608bb
    systemd.machine_id=edf4d6281d4d4426913b3410df33de89
  Desktop: KDE Plasma v: 6.8.1 tk: Qt v: N/A info: frameworks v: 6.31.0
  Type: Desktop Mobo: Gigabyte model: B850 AORUS ELITE WIFI7 v: x.x
    serial: <superuser required> uuid: <superuser required> Firmware: UEFI
    vendor: American Megatrends LLC. v: F6 date: 07/16/2025
  Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MCP arch: Zen 5 gen: 5
    level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
    model-id: 0x44 (68) stepping: 0 microcode: 0xB404035
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 8 smt: <unsupported> cache:
    L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB
    L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 603 min/max: 603/5272 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 603 2: 603 3: 603
    4: 603 5: 603 6: 603 7: 603 8: 603 bogomips: 75085
    ssse3 svm
  Vulnerabilities:
  Type: gather_data_sampling status: Not affected
  Type: ghostwrite status: Not affected
  Type: indirect_target_selection status: Not affected
  Type: old_microcode status: Not affected
  Type: reg_file_data_sampling status: Not affected
  Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
    prctl
    sanitization
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB:
    conditional; STIBP: disabled; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: tsa status: Not affected
  Type: vmscape mitigation: IBPB on VMEXIT
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
    XT/9070 GRE] vendor: XFX driver: amdgpu v: kernel arch: RDNA-4
    code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie: gen: 5
    speed: 32 GT/s lanes: 16 ports: active: DP-2,DP-3,HDMI-A-1
    empty: DP-1,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Granite Ridge [Radeon 610M]
    vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: none empty: DP-4, DP-5, DP-6, HDMI-A-2,
    Writeback-2 bus-ID: 12:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 40.0 C
  Display: wayland server: X.org v: 1.21.1.25 with: Xwayland v: 24.1.14
    gpu: amdgpu d-rect: 3840x2160 display-ID: 1
  Monitor-1: DP-2 pos: bottom-l model: Idek Iiyama PL2770H serial: <filter>
    built: 2022 res: mode: 1920x1080 hz: 165 scale: 100% (1) dpi: 82 gamma: 1.2
    size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  Monitor-2: DP-3 pos: primary,top-left model: Samsung S27E650
    serial: <filter> built: 2015 res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
    ratio: 16:9 modes: max: 1920x1080 min: 720x400
  Monitor-3: HDMI-A-1 pos: top-right model: LG (GoldStar) TV
    serial: <filter> built: 2013 res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 30 gamma: 1.2 size: 160x90mm (6.3x3.54") diag: 1836mm (72.3")
  API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi
    surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 vendor: amd mesa v: 26.2.5-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 9070 XT (radeonsi gfx1201 ACO
    DRM 3.64 6.18.58-1-lts) device-ID: 1002:7550 memory: 15.62 GiB unified: no
  API: Vulkan v: 1.4.363 layers: 6 device: 0 type: discrete-gpu name: AMD
    Radeon RX 9070 XT (RADV GFX1201) driver: mesa radv v: 26.2.5-arch1.1
    device-ID: 1002:7550 surfaces: N/A device: 1 type: integrated-gpu name: AMD
    Ryzen 7 9800X3D 8-Core Processor (RADV RAPHAEL_MENDOCINO)
    driver: mesa radv v: 26.2.5-arch1.1 device-ID: 1002:13c0 surfaces: N/A
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
    driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
    bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 12:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Gigabyte
    bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: SC420 USB Microphone driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-1.1:3
    chip-ID: 3212:1a03 class-ID: 0300 serial: <filter>
  API: ALSA v: k6.18.58-1-lts status: kernel-api
  Server-2: PipeWire v: 1.6.10 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8922AE 802.11be PCIe Wireless Network Adapter
    driver: rtw89_8922ae v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    port: d000 bus-ID: 09:00.0 chip-ID: 10ec:8922 class-ID: 0280
  Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: c000 bus-ID: 0a:00.0
    chip-ID: 10ec:8125 class-ID: 0200
  IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Info: services: NetworkManager, systemd-timesyncd, wpa_supplicant
Bluetooth:
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:7 chip-ID: 0bda:8922
    class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: disabled
  Local Storage: total: 4.21 TiB used: 3.12 TiB (74.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 7B2QJXD7 temp: 42.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: FireCuda SE SSD
    ZA2000GM10011 size: 1.82 TiB block-size: physical: 512 B logical: 512 B
    speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: D013 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 1TB
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-5: /dev/sdd maj-min: 8:48 model: USB DISK 2.0 size: 117.19 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
    lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: PMAP scheme: MBR
  SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
  ID-1: / raw-size: 929.51 GiB size: 913.85 GiB (98.31%)
    used: 509.11 GiB (55.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  System Temperatures: cpu: 45.2 C mobo: 33.0 C
  GPU: device: amdgpu temp: 54.0 C mem: 54.0 C fan: 0 watts: 40.00
    device: amdgpu temp: 53.5 C
  Memory: total: 32 GiB note: est. available: 30.46 GiB used: 4.39 GiB (14.4%)
  Processes: 343 Power: uptime: 38m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.14 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 262 default: graphical
    tool: systemctl
  Packages: 1499 pm: pacman pkgs: 1467 libs: 386 tools: yay pm: flatpak
    pkgs: 32 Compilers: clang: 23.1.3 gcc: 16.2.1 Shell: Zsh v: 5.9.2
    running-in: konsole inxi: 3.3.41
I hope someone can help me get this solved.
