Hi guys! Recently got a problem with a steam download speed. It’s downloading files like 1 or 2 mbps even tho my internet speed is supposed to be 100 mbps. How could I fix it?
I also got this cron autostart commands (maybe them causing the problem):
@reboot /usr/bin/iw dev wlan0 set power_save off @reboot /usr/bin/ip link set wlan0 mode default @reboot /usr/bin/ip link set wlan0 mtu 1250
I can’t delete them because if I do so, my wifi will be dying every 2-5 minutes and steam won’t open without MTU set to 1250 (my provider problem)
P.S I download via wifi and it is not it’s problem because everything except steam works just fine
I’m pretty sure this is a Linux setup thing. OP is not the first one with this problem. I also got the same problem for some months. Download speed outside of steam was fine, but steam was slow.
First time I had the problem it was resolved after trying out PopOS, the second time a new server setting in steam helped me.
