When I go into sleep mode (let’s say before bed – at 80% battery) and then I open up my laptop again later (when I wake up), my battery is completely drained.
I tried:
(1) echo deep > /sys/power/mem_sleep after I saw that cat /sys/power/mem_sleep had s2idle selected instead of deep. But that did not seem to fix the issue… that being said on reboot it is back at s2idle instead of deep… RedditPost. If I also then try to write mem to /sys/power/state after that, the laptop screen will not turn back on no matter what and I have to hard shutdown and restart (which I know is bad, but I try everything else first).
(2) I read in the above link, that to make the change to deep permenant to try changing "in your kernel cmdline in your bootloader: mem_sleep_default=deep" – but I haven’t figured out how to do that or where that is.
(3) TLP is already installed
(4) While I see reports of sleep being an issue for some Dell XPS computers, sleep has worked fine in Windows and a previous linux installation before on this same laptop
(5) Output of systemctl suspend journalctl | grep "PM: suspend" gives Jan 19 09:28:08 keith-xps139300 kernel: PM: suspend entry (s2idle) Jan 19 09:28:31 keith-xps139300 kernel: PM: suspend exit – which I want deep, but not sure how to change that
– If I had to guess, I hope that I just need to figure out how to execute #2 “change mem_sleep_default to deep in linux kernel commandline”. I saw that mentioned here too Linux Sleep States but again, I cannot figure out how to actually do that.
Here’s some potentially helpful information on my system:
inxi --full --admin --verbosity=7 --filter --no-host
System: Kernel: 5.10.8-arch1-1 x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-linux
root=UUID=00c1d828-42cc-4e2b-93f7-c6c15462005f rw quiet loglevel=3 nowatchdog
Desktop: Deepin 20.1 tk: Qt 5.15.2 info: dde-dock wm: kwin_x11 dm: LightDM 1.30.0
Distro: EndeavourOS
Machine: Type: Laptop System: Dell product: XPS 13 9300 v: N/A serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: Dell model: 077Y9N v: A00 serial: <filter> UEFI: Dell v: 1.4.1
date: 11/23/2020
Battery: ID-1: BAT0 charge: 25.8 Wh condition: 45.5/51.0 Wh (89%) volts: 8.1/7.6
model: SMP DELL WN0N005 type: Li-poly serial: <filter> status: Charging
Memory: RAM: total: 15.22 GiB used: 2.23 GiB (14.6%)
RAM Report: missing: Required program dmidecode not available
CPU: Info: Quad Core model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake
family: 6 model-id: 7E (126) stepping: 5 microcode: A0 L2 cache: 8 MiB
bogomips: 23968
Speed: 3800 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 3800 2: 3800 3: 2071
4: 3806 5: 1935 6: 2054 7: 1389 8: 1941
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts
clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm
fxsr gfni ht hwp hwp_act_window hwp_epp hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr
mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku
pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good sdbg sep sha_ni
smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx
vnmi vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled
Type: spec_store_bypass
mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB filling
Graphics: Device-1: Intel Iris Plus Graphics G7 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:8a52
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 3-9:3
chip ID: 0bda:5511 serial: <filter>
Display: x11 server: X.org 1.20.10 compositor: kwin_x11 driver: intel
unloaded: fbdev,modesetting,vesa resolution: <missing: xdpyinfo>
Audio: Device-1: Intel Smart Sound Audio vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:34c8
Device-2: Realtek USB Audio type: USB driver: snd-usb-audio bus ID: 5-2.3.4:7
chip ID: 0bda:402e serial: <filter>
Sound Server: ALSA v: k5.10.8-arch1-1
Network: Device-1: Intel Killer Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter
vendor: Bigfoot Networks driver: iwlwifi v: kernel port: 4000 bus ID: 00:14.3
chip ID: 8086:34f0
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
IP v6: <filter> type: noprefixroute scope: link
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
bus ID: 6-2.4:4 chip ID: 0bda:8153 serial: <filter>
IF: enp3s0u2u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
WAN IP: <filter>
RAID: Message: No RAID data was found.
Drives: Local Storage: total: 957.62 GiB used: 61.57 GiB (6.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEMKF010T8 NVMe 1024GB
size: 953.87 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 7003 temp: 36.9 C
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer size: 3.75 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: 8.02
SMART Message: Unknown USB bridge. Flash drive/Unsupported enclosure?
Message: No Optical or Floppy data was found.
Partition: ID-1: / raw size: 390.62 GiB size: 383.49 GiB (98.17%) used: 61.48 GiB (16.0%)
fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: 00c1d828-42cc-4e2b-93f7-c6c15462005f
ID-2: /boot/efi raw size: 190 MiB size: 186 MiB (97.89%) used: 91.2 MiB (49.0%)
fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: ESP uuid: 30DF-6832
ID-3: /run/media/keithd/ENDEAVOUROS raw size: 1.81 GiB size: <superuser required>
used: <superuser required> fs: iso9660 dev: /dev/sda1 maj-min: 8:1
label: ENDEAVOUROS uuid: 2020-09-20-20-31-31-00
Swap: Alert: No Swap data was found.
Unmounted: ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 547.55 GiB fs: bitlocker label: N/A
uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 990 MiB fs: ntfs label: WINRETOOLS
uuid: 3830AA4330AA07C8
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 13.11 GiB fs: ntfs label: Image
uuid: F812AA9A12AA5D7E
ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 1.3 GiB fs: ntfs label: DELLSUPPORT
uuid: BE181DA1181D59AB
ID-6: /dev/sda2 maj-min: 8:2 size: 64 MiB fs: vfat label: ARCHISO_EFI
uuid: 8D52-3AEA
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 3-5:2 info: Shenzhen Goodix FingerPrint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 27c6:533c
Device-2: 3-9:3 info: Realtek Integrated_Webcam_HD type: Video driver: uvcvideo
interfaces: 5 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:5511 serial: <filter>
Device-3: 3-10:4 info: Intel type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s chip ID: 8087:0026
Hub: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Hub: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 5-2:2 info: Realtek Dell dock ports: 5 rev: 2.1 speed: 480 Mb/s
chip ID: 0bda:5487
Hub: 5-2.3:3 info: Realtek Dell dock ports: 6 rev: 2.1 speed: 480 Mb/s
chip ID: 0bda:5413
Device-1: 5-2.3.1:5 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
chip ID: 046d:c52b
Device-2: 5-2.3.2:6 info: SanDisk Cruzer type: Mass Storage driver: usb-storage
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 0781:5530 serial: <filter>
Device-3: 5-2.3.4:7 info: Realtek USB Audio type: Audio driver: snd-usb-audio
interfaces: 4 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:402e serial: <filter>
Device-4: 5-2.3.5:8 info: Dell Dell dock type: HID driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 413c:b06f
Device-5: 5-2.5:4 info: Dell Dell dock type: HID driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 413c:b06e
Hub: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Hub: 6-2:2 info: Realtek Dell dock ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 0bda:0487
Hub: 6-2.3:3 info: Realtek Dell dock ports: 4 rev: 3.1 speed: 5 Gb/s
chip ID: 0bda:0413
Device-1: 6-2.4:4 info: Realtek RTL8153 Gigabit Ethernet Adapter type: Network
driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s chip ID: 0bda:8153
serial: <filter>
Sensors: System Temperatures: cpu: 58.0 C mobo: N/A
Fan Speeds (RPM): cpu: 5438 mobo: 5093 fan-2:
Info: Processes: 262 Uptime: 3m wakeups: 952 Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: pacman: 1244 lib: 419 Shell: Bash v: 5.1.4 running in: deepin-terminal
inxi: 3.2.01
Thank you!
