I’ve been using EOS as my primary OS for the last three months and overall I’m extremely pleased with the system. Unfortunately two annoying errors occured out of the blue during the last couple of weeks:
Sleep stopped working on my system
The pacman hook “Reloading device manager configuration” after updating packages exits with an error.
As I am fairly new to debugging on Linux could anyone help me with fixing those two errors?
I had a look at the pacman log but wasn’t able to find a cause for 2).
It’s been a while but since I haven’t resolved my issue so far, I’m following up. I’m still having the two problems mentioned above, 1) sleep is not working, 2) there is an error when pacman is doing the hook “Reloading device manager configuration…”. Switching to the LTS kernel didn’t help either.
udevadm control --reload-rules && udevadm trigger also gives me an error.
Can you share the full error message you are getting when you get errors? There may be something there that gives us a clue as to what the issue might be.
the journal is full of pcieport warnings and bus errors. that’s the reason why the log is that huge… if this massive log spamming happens it will already on its own slow down system and can cause issues on its own…
Thank you very much for making me aware of the PCI bus errors. I googled for similar errors and found someone getting similar errors on the Intel X99 platform. I added “pcie_aspm=off” as a kernel parameter to GRUB_CMDLINE_LINUX_DEFAULT which apparently solved my issues.
