Well, I tried to run Slack natively on my endeavourOS with no success !
I was able to install through yay as its provided in aur .
On launching , It redirects to the Web Browser for loging in . However , slack is stuck at the login window when the browser opens it as xdg-app.
In addition , the official slack website https://slack.com/intl/en-in/ has .rpm (I tried making pkg from rpm but failed at installation), .deb packages and snap store option which I dont prefer .
I have to use Slack in the browser which isnāt so great.
Any help .Thanks .
Id contact Slack upstream and see if they can offer a proper fix, here you may get a workaround or 2 but the devs know their program best
if you need advise on how to do thisl ill try my best to walk you through it
What do you mean by āstuckā here? Which browser is it loading in? Do you have browser extensions that are blocking resources?
The browser actually opens Slack after giving correct credentials but still Slack is āstuckā at the login Window
Yes please !
Give me a bit but will post it here soon, using the phone for a keyboard at the monent but will ttry post how to soon
sorry if it takes me a bit, will probably just post links for now, this phone is annoying to use
Just want to confitm you have been through this?
Canāt replicate the issue here. I sign into Slack in the browser, it asks me to select a workspace, then the browser prompts to open the Slack application and it loads correctly.
Same here, zero issues installing or logging in
Could you try using another web browser? I am guessing you are using something Chromium-based as you mention xdg-app so perhaps set your default web browser to Firefox and try again?
What happens when you click the āSign In to Slackā button when youāre signed in in the browser?
It may be a KDE plasma issue.
Run this in a terminal:
while true; do ps aux|grep '[s]lack' | grep magic ; sleep 1; done
Open slack, try to log in, wait for a URL to appear on the terminal, like this: slack://<workspace_id>/magic-login/<magic numbers>
Convert WORKSPACE_ID letters to uppercase, and run this: slack --enable-crashpad slack://<WORKSPACE_ID>/magic-login/<magic numbers>
This solution works. Thanks!
