Silent boot with Systemd
A short time ago @dalto helped me with my question about how to get rid of this…
It was super easy to do, so thanks dalto.
Now I would like to silence this…
I used to know how to do it when I booted with Grub, but now I use Systemd. I did search around, but I was worried about doing something which might make my system unbootable.
I don’t use systemd-boot, not sure where the loader.conf is, but you can try changing the timeout to 0 https://wiki.archlinux.org/title/systemd-boot#Loader_configuration
Thanks, I’ll check this out and report back. :smiley:
I would actually advise against removing the view completely. If something happens to your system you will have to make other means to hit fall back mode. I would suggest just shortening the time.
filename and location should be
/efi/loader/loader.conf
Thanks again, all done. :smiley:
Thanks my friend, noted. :smiley:
it says in the wiki you can bring it back with space
