Signal-desktop is not working
Hello *, I am new here & just moved over from Manjaro. I have a fresh KDE install and am trying to get all my stuff running. I installed signal-desktop with yay. However, when I start it the signal window opens but I can’t do anything: Clicking on the menus doesn’t work. I can only close the window again.
The shell gives this:
NODE_ENV production
NODE_CONFIG_DIR /usr/lib/signal-desktop/resources/app.asar/config
NODE_CONFIG {}
ALLOW_CONFIG_MUTATIONS undefined
HOSTNAME mars
NODE_APP_INSTANCE undefined
SUPPRESS_NO_CONFIG_WARNING undefined
SIGNAL_ENABLE_HTTP undefined
userData: /home/mebs/.config/Signal
(node:160090) [DEP0180] DeprecationWarning: fs.Stats constructor is deprecated.
(Use `signal-desktop --trace-deprecation …` to show where the warning was created)
[160090:0615/222222.366607:ERROR:ui/ozone/platform/wayland/host/wayland_wp_color_manager.cc:277] Unable to set
image transfer function.
[160090:0615/222222.366618:ERROR:ui/ozone/platform/wayland/host/wayland_wp_color_manager.cc:195] Failed to pop
ulate image description for color space {primaries:BT709, transfer:SRGB, matrix:RGB, range:FULL}
[160090:0615/222223.041194:ERROR:ui/ozone/platform/wayland/host/wayland_wp_color_manager.cc:277] Unable to set
[160090:0615/222223.041208:ERROR:ui/ozone/platform/wayland/host/wayland_wp_color_manager.cc:195] Failed to pop
[160090:0615/222223.041217:ERROR:ui/ozone/platform/wayland/host/wayland_wp_color_management_surface.cc:64] Fai
led to get image description for color space.
[160090:0615/222223.065780:ERROR:ui/ozone/platform/wayland/host/wayland_wp_color_manager.cc:277] Unable to set
[160090:0615/222223.065791:ERROR:ui/ozone/platform/wayland/host/wayland_wp_color_manager.cc:195] Failed to pop
[160090:0615/222223.066144:ERROR:ui/ozone/platform/wayland/host/wayland_wp_color_manager.cc:277] Unable to set
[160090:0615/222223.066148:ERROR:ui/ozone/platform/wayland/host/wayland_wp_color_manager.cc:195] Failed to pop
I uninstalled & reinstalled it using flatpak - same thing.
How come? What do?
Thx, Ricky
signal-desktop --ozone-platform=x11
Does that help?
Just installed and runs here on mangowm. What are you running?
Yes! Thank you!
Please mark @xircon’s post as solution, thanks!
