I installed EOS with root on another drive. And a section of /etc/mkinitcpio.conf
says to include shutdown, fsck and usr under the HOOKS section.
I don’t know “how” do I add these to it. Like what lines are to be added to the file, because I am a newbie. If someone could list it?
Thanks.
neofetch output for reference:
./o. user@endeavourOS
./sssso- -----------------
`:osssssss+- OS: EndeavourOS Linux x86_64
`:+sssssssssso/. Host: HP Laptop 15s-gr0xxx
`-/ossssssssssssso/. Kernel: 5.16.3-zen1-1-zen
`-/+sssssssssssssssso+:` Uptime: 7 mins
`-:/+sssssssssssssssssso+/. Packages: 1081 (pacman)
`.://osssssssssssssssssssso++- Shell: bash 5.1.16
.://+ssssssssssssssssssssssso++: Resolution: 1920x1080
.:///ossssssssssssssssssssssssso++: DE: Plasma 5.23.5
`:////ssssssssssssssssssssssssssso+++. WM: KWin
`-////+ssssssssssssssssssssssssssso++++- Theme: Breeze Light [Plasma], Breeze [GTK2/3]
`..-+oosssssssssssssssssssssssso+++++/` Icons: [Plasma], breeze-dark [GTK2/3]
./++++++++++++++++++++++++++++++/:. Terminal: konsole
`:::::::::::::::::::::::::------`` CPU: AMD Ryzen 3 3250U with Radeon Graphics (4) @ 2.600GHz
GPU: AMD ATI Radeon Vega Series / Radeon Vega Mobile Series
Memory: 1443MiB / 13989MiB
Also refer to this article to understand what I am trying to do: https://www.reddit.com/r/ManjaroLinux/comments/oq2aez/fix_for_slow_shutdown_and_reboot_on_manjaro_kde/
Just open /etc/mkinitcpio.conf
with sudo nano
like so sudo nano /etc/mkinitcpio.conf
Then you find the line that looks like below.
HOOKS=(base udev autodetect keyboard modconf block filesystems resume fsck)
You can add the hooks within the brackets. But please double-check first. And then rebuild the initframes using sudo mkinitcpio -P
Hello,
I did as you said. Below is the output of mkinitcpio -P
==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'default'
-> -k /boot/vmlinuz-linux -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
==> Starting build: 5.16.4-arch1-1
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [filesystems]
-> Running build hook: [usr]
-> Running build hook: [fsck]
-> Running build hook: [shutdown]
==> Generating module dependencies
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux.img
==> Image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux.preset: 'fallback'
-> -k /boot/vmlinuz-linux -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: aic94xx
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: wd719x
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'default'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen.img
==> Starting build: 5.16.3-zen1-1-zen
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen.img
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'fallback'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen-fallback.img -S autodetect
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen-fallback.img
I think it worked. Please confirm.
Looks good no error the warnings are kind of normal.
system
Closed
5
