Vicky
January 5, 2023, 1:20pm
1
Hi…
The gui of openshot and shotcut having some issues.
Not sure if this is because of some graphics issue. I have never tried these software in my laptop. Working fine in my personal computer but not in laptop.
below is the result of inxi -Gxxx.
Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Lenovo
driver: i915 v: kernel arch: Gen-5 ports: active: LVDS-1 empty: DP-1,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:2a42 class-ID: 0300
Display: x11 server: X.Org v: 21.1.6 compositor: xfwm v: 4.18.0 driver: X:
loaded: intel unloaded: modesetting alternate: fbdev,vesa dri: i965
gpu: i915 display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 mapped: LVDS1 model: Chi Mei Opto 0x1465 res: 1366x768
hz: 60 dpi: 112 size: 310x180mm (12.2x7.09") diag: 358mm (14.1")
modes: 1366x768
API: OpenGL v: 2.1 Mesa 22.3.2 renderer: Mesa Mobile Intel GM45 Express
(CTG) direct render: Yes
dalto
January 5, 2023, 1:32pm
2
What is model number of the CPU?
It is generally better to provide a full inxi -Fxxxz
Vicky
January 5, 2023, 3:05pm
3
Hi @dalto ,
Please find the below results for inxi -Fxxxz
[vicky@vicky-home ~]$ inxi -Fxxxz
Kernel: 5.15.86-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: Xfce v: 4.18.0 tk: Gtk v: 3.24.35 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: EndeavourOS base: Arch Linux
Type: Laptop System: LENOVO product: INVALID v: Lenovo B460e
serial: <superuser required>
Mobo: LENOVO model: N/A serial: <superuser required> BIOS: LENOVO
v: 4FCNA1WW date: 12/26/2011
Battery:
ID-1: BAT0 charge: N/A condition: N/A volts: N/A model: N/A type: Li-ion
serial: <filter> status: N/A
Info: dual core model: Pentium T4500 bits: 64 type: MCP smt: <unsupported>
arch: Penryn rev: A cache: L1: 128 KiB L2: 1024 KiB
Speed (MHz): avg: 1227 high: 1258 min/max: 1200/2300 cores: 1: 1258
2: 1197 bogomips: 9177
Flags: ht lm nx pae sse sse2 sse3 ssse3
modes: 1366x768
Device-1: Intel 82801I HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:293e class-ID: 0403
Sound API: ALSA v: k5.15.86-1-lts running: yes
Sound Server-2: PipeWire v: 0.3.63 running: yes
vendor: Lenovo driver: r8168 v: 8.051.02-NAPI pcie: speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter type: USB
driver: rtl8188fu bus-ID: 1-4:2 chip-ID: 0bda:f179 class-ID: 0000
serial: <filter>
Local Storage: total: 223.57 GiB used: 107.92 GiB (48.3%)
ID-1: /dev/sda vendor: Kingston model: SUV400S37240G size: 223.57 GiB
speed: 3.0 Gb/s type: SSD serial: <filter> rev: D6SD scheme: GPT
ID-1: / size: 105.88 GiB used: 33.12 GiB (31.3%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 105.18 GiB used: 73.49 GiB (69.9%) fs: ext4
dev: /dev/sda3
ID-1: swap-1 type: partition size: 8 GiB used: 1.31 GiB (16.3%) priority: -2
dev: /dev/sda1
System Temperatures: cpu: 55.0 C mobo: N/A
Fan Speeds (RPM): N/A
Processes: 203 Uptime: 1h 53m wakeups: 1 Memory: 3.74 GiB
used: 3.13 GiB (83.8%) Init: systemd v: 252 default: graphical Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1351 Shell: Bash
v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.24
dalto
January 5, 2023, 3:55pm
4
I believe that is supported by the modesetting driver. Try uninstalling xf86-video-intel and rebooting.
Vicky
January 8, 2023, 1:30pm
5
Hi @dalto ,
I tried uninstalling but same issue. Again reinstalled and tried, still same issue.
Vicky
January 10, 2023, 2:07pm
6
A gentle reminder ! Can someone please check and update on this one
Vicky
January 12, 2023, 1:41pm
7
Hi, Can someone please check and update on this issue.
dalto
January 12, 2023, 1:47pm
8
Did you reboot with it uninstalled?
You are not being ignored. It is likely that nobody who has read this knows the answer to your question.
Vicky
January 12, 2023, 2:06pm
9
Hi @dalto ,
Yes i have rebooted after i uninstalled it and then checked. Again after reinstalling and checked.
Still issue is there.
