Shortcut Keys Not Working
I have installed endeavour os lxde because of my low end laptop
how can I use my shortcut keys
for eg = f12 for increasing brightness, f1 to mute, f2 to decrease volume, f3 to increase volume
If i press them nothing happens
how can I enable them
please help
I am a complete newbie
I’d probably have started with the standard Xfce desktop given that’s the default and the one most people here will be using.
Generally, there will be a modifier that will trigger the alternative behaviour, e.g. a Fn key. Then, something has to be listening for the keypress. What does LXDE use to listen for the keypresses?
Generally speaking, the best place for any “complete newbie” to start is with some reading - for example, you might consider obtaining an “Introduction to Linux” book. The Arch wiki also has a lot of very useful information but it is also quite dense: https://wiki.archlinux.org/title/LXDE
Welcome to :enos: forums.
You can find the keybinds at ~/.config/openbox/lxde-rc.xml you can edit the file to add your own. For further help this would help.
EDIT: Moved the thread to Desktop Environments.
Welcome to the forum :partying_face:
I have tried opening this file by entering it’s location in file manager search bar
It was showing no file or directory
I also tried to open this using terminal the same error was coming
btw thanks for the reply
Thanks
I would try my best to be useful in this forum
I tried using xfce
but because of my slow processor things we were taking a bit longer than usual to open up
and my ram is also very less and slow (gets filled very easily)
so switching to lxde I think is a step worth doing for me
I do not know
I will surely check it out
.config file is in you home directory it’s a hidden folder press Ctrl + H to see the hidden files and folders. If it’s not there you need to copy the file from /etc/xdg/openbox/rc.xml to ~/.config/openbox/rc.xml to ~/.config/openbox/.
Also, our bspwm or i3 would might suite you.
yeah I followed the instructions you have given
and after opening the file this is showing
<?xml version="1.0" encoding="UTF-8"?>
<openbox_config xmlns=“http://openbox.org/3.4/rc”>
10
<screen_edge_strength>20</screen_edge_strength>
yes
no
yes
no
200
no
Smart
yes
Any
Mikachu
NLIMC
yes
yes
sans
10
bold
normal
sans
10
bold
normal
sans
10
normal
normal
sans
10
normal
normal
sans
10
bold
normal
Sans
8
Sans
8
<!-- this stuff is only used at startup, pagers allow you to change them
during a session
   these are default values to use when other ones are not already set
   by other applications, or saved in your session
   use obconf if you want to change these without having to log out
   and back in -->
<number>2</number>
<firstdesk>1</firstdesk>
<names>
  <!-- set names up here if you want to, like this:
<name>desktop 1</name>
<name>desktop 2</name>
</names>
<popupTime>875</popupTime>
<!-- The number of milliseconds to show the popup for when switching
   desktops.  Set this to 0 to disable the popup. -->
yes Nonpixel Center 10 10 0 0 0 0 TopLeft 0 0 no Above Vertical no 300 300 Middle C-g no no no no no no no no no no no no no no no no 1 2 3 4 client-menu yes yes true PCManFM pcmanfm pcmanfm --find-files lxpanelctl run lxpanelctl run lxpanelctl menu lxpanelctl menu lxtask gnome-screenshot -i lxrandr 8 200 400 client-menu top left right bottom client-menu client-menu client-menu client-list-combined-menu root-menu /usr/share/lxde/openbox/menu.xml 200 no 100 yes yes
Read openbox wiki page http://openbox.org/wiki/Help:Bindings which shows you how to add the bindings to that file. Our openbox online edition comes with all default settings so the user has to customize it to fit his needs.
It’s better you read their entire help document section or use it as a reference. Link: http://openbox.org/wiki/Help:Contents
How much RAM do you have? 4gb can run everything pretty easily. 2gb I’d suggest MATE for a full featured DE and still usable. Lxde is great but very basic. That is what keeps it light though.
I have 4 gb ram of which 3.26 is usable
and the speed of my ram is 1600 mhz
my processor is of amd a6 1.8 ghz
xfce runs on it
but I am learning web development
and coding in vs code alongside using browser is very painstaking
everything starts to freeze with extreme lags
but switching to lxde solved all the problem
It is more fast and snappy for me
but I think I need to switch from it too
as my bluetooth is not working properly
nor the shortcut keys on the keys
and the volume management is very poor too
Try a bspwm or i3 edition that hardly uses RAM or resources.
ok I am installing plasma straight away
will see what will happen
How did you set it up?
im not sure if you resolved this but some of those shortcuts are linked to vendor specific software in Windows.
What model laptop do you have?
downloaded blueman bluetooth manager
I Have switched to xfce
and I am facing no problem
thanks for the concern btw
