Shortcut for Monitor Change don't work
KDE Plasma 6.2
WM kwin
Hello
Normaly I can select my with Win Key + P my monitor configuration. With KDE Plasma this shortcut dont’t work. Any hint ?
Greatings
I’m not sure why it isn’t working for you. What I would suggest to rule out things is to make a new user and test it there to see if it works. (You did check the settings to make sure it’s on?)
Looks pretty old or is it a typo and you wanted to say 6.6.2?
