Setting XDG_CONFIG_HOME
I see lots of references to this env variable. It appears that packages being installed that need this value will default to $HOME/.config if the variable isn’t set.
Should I set this variable? If so, where should I do it to have maximum effect on startup?
If not, why do we even refer to XDG_CONFIG_HOME?
I don’t have it set on any of my installs.
Perhaps to give you the ability to override the default if you need to?
Fair enough. Thanks, dalto
