Setting up graceful shutdown
Hello everyone!
I’ve recently gotten an Uninterrupted Power Supply for my computer which I setup to shutdown my computer. In case the battery within the UPS were to ever run low on power, I expected the UPS to gracefully shutdown the computer to avoid abruptly closing down processes, however, in a recent power event it would seem that this did not occur. From what i can gather, it seems that the daemon that handles the shutdown is using systemctl poweroff which on my system immediately shuts off the computer without doing much to request processes to close themselves.
I did some research regarding how to potentially do this, and apparently there may be a way to do as such by sending sigterm signals to every process, allowing for a process to do what it needs to do before shutting off (ex. closing databases, saving documents, etc.). There is also something regarding systemctl where one may potentially be able to modify the behavior of units used by systemctl, like that of poweroff, but i fear modifying a built in unit may lead to unexpected issues down the road.
Is there a recommended way to set up poweroff or similar things to gracefully shutdown a system? Having a way to prompt the user that applications are open similar to that to Windows for example, or just automatically requesting the closing of or the sending of term or other similar signals to processes?
systemctl poweroff is considered a “graceful” shutdown. The system goes through the full, “proper” shutdown sequence, including stopping services and unmounting filesystems in an orderly manner. Processes have a chance to terminate cleanly, data is written to disk, and so on.
When you run systemctl poweroff, the system does send SIGTERM to all running processes. Each process has a chance to terminate gracefully. If a process can’t terminate within a specified timeout, it is then sent SIGKILL to forcefully terminate it.
Generally the default timeout is 90 seconds, but if you have a process that needs more time you can specify a custom TimeoutStopSec parameter under the [Service] section of the unit file. For example, to set a five-minute timeout:
[Service]
ExecStart=/path/to/your/executable
TimeoutStopSec=5min
Keep in mind, in Linux applications are often willing to immediately shut down without all the hand-wringing and “are you sure?!” that you may be used to from Windows. If you want prompts that appear asking you to save your work or whatever, depending on the application you may need to set that up yourself.
If you put together a script that handles whatever your special shutdown stuff is, you can incorporate it into systemd’s shutdown routine by putting the script in a service file and adding the Before=shutdown.target directive.
[Unit]
Description=My Really Awesome Shutdown Script
DefaultDependencies=no
[Service]
Type=oneshot
ExecStart=/path/to/my_really_awesome_shutdown_script.sh
RemainAfterExit=true
[Install]
WantedBy=halt.target reboot.target shutdown.target
That’s just an example obviously, but in general if a service file just runs a script it does not need to be complex.
systemctl poweroff is not a systemd unit itself; rather, it is a command that kicks off the systemd shutdown process. Essentially, running systemctl poweroff tells systemd “go ahead and start doing all the stuff you need to do before the computer shuts off, and then shut it off.”
As for modifying service files, in general it is fine if you want to make a change. In fact, systemd makes it fairly easy to do by using a drop-in system; essentially, you can make “edits” to a service unit without modifying the original unit files. Your special modifications are kept in a separate file that systemd will honor when it is running that service. If you want to learn more about that, take a look at this article here: https://wiki.archlinux.org/title/Systemd#Drop-in_files
Apologies for the late reply and thank you for your solution along with the informative response! In regards to the information you’ve provided on how systemctl poweroff works, yeah, thats basically what i’ve picked up from all my research around it. However, I feel my system may be behaving differently from what has been described.
On my system, once a shutdown starts, everything immediately goes down with little to no pause with applications seemingly being killed before they are able to stop whatever they may be doing. Running either systemctl poweroff and shutdown -h now produce the same outcome explained above. Perhaps this is what you described where certain applications will just immediately shutdown which is unfortunately not the behavior I want.
A thing of note that i discovered is that kill -15 <ID> to which from my understanding is supposed to send a sigterm to the specified process, is able to initiate a safe closing procedure for certain applications. poweroff also sends sigterm as we have discussed and which is documented, however, it isn’t able to replicate the behavior of kill oddly enough for certain applications even though they both send sigterm. I’m going to assume that the applications in question probably aren’t communicating with the system that they are in the process of shutting themselves down. This in turn causing the system to interpret the radio silence as the applications having already finished with its closure, resulting in the abrupt shutdown.
I will definitely be incorporating this into a shutdown script, perhaps with some sort of delay to give more leeway for these applications to do what they need to do. And once again, thank you for pointing me in the right direction and providing additional information around systemctl!
