I’m trying to set my EOS/Cinnamon keyboard like I’m used to for so many years on Mint, but I seem to be missing something. Who can help?
The basic keyboard layout is “German (dead tilde)”.
In Settings → Keyboard → Options , I have
Unicode arrows and math operators on default level
Non-breaking space on 2nd level
Compose Key is Caps Lock key
I also use a rather complex .XCompose.
Now the keyboard settings preview shows the correct layout, but it doesn’t work , and neither does my .XCompose file.
The Caps Lock still does Caps Lock (not Compose).
Could it be I need to install something extra, or somehow set another input method? I do also need the Ctrl+Shift+u Unicode input. (This might rule out xim, but I guess ibus is used nowadays?)
Tried re-login, reboot, but to no avail.
Okay, my own dim remembrance of ibus was the solution:
Install ibus from the repos
Install ibus-autostart from the AUR
and then:
Cinnamon keyboard settings are respected
Compose works (with my .XCompose file)
Ctrl+Shift+u Unicode input still works
A kbd layout switcher is added to the tray (don’t really need that)
Phew. Hooray!
So great being able to type “normally” again! Finger memory is really a thing…
Just in case anyone is as crazy as I am—here is the .XCompose I’ve been using (and evolving) over the years:
.XCompose
# ~/.XCompose
# This file defines custom Compose sequence for Unicode characters
# 2021-10-26 Matthias C. Hormann aka Moonbase59
# Import default rules from the system Compose file:
include "%L"
# Extra Math symbols
<Multi_key> <minus> <period> : "−" U2212 # MINUS SIGN
<Multi_key> <period> <slash> <period> : "⁒" U2052 # COMMERCIAL MINUS SIGN
This file has been truncated. show original
XCompose Tree, in typing sequence.txt
hit end
Greek_accentdieresis
Greek_iota "ΐ" U0390 # GREEK SMALL LETTER IOTA WITH DIALYTIKA AND TONOS
Greek_upsilon "ΰ" U03b0 # GREEK SMALL LETTER UPSILON WITH DIALYTIKA AND TONOS
Multi_key
0
3 "↉" U2189 # VULGAR FRACTION ZERO THIRDS
asciitilde "⍬" U236c # APL FUNCTIONAL SYMBOL ZILDE
asterisk "°" U00b0 # DEGREE SIGN
1
The Gist also includes a tree listing, in typing sequence.
Ben
April 26, 2025, 1:53pm
4
There are a few… just had to edit a few of those before importing though (LLAP is better llap)…
I started out with ‘degc’ to type ‘32°C’ because I couldn’t remember the proper shortcut… then added some phonetics - it’s hard to write sounds and not conflict spellings… so ‘Ow!’ is aʊ…
But for sure, quite an OTT collection.
