Separate hard drive installs of Win11/Endeavor issue
Hey all, I went to install Endeavor on a second hard drive on my PC, and it seemed to destroy the Win11 MBR and only allow me to boot into Endeavor (I’m not sure thats actually what happened, just the result).
When I originally did this, it didn’t happen. Am I missing something in the install process to have a proper multi-boot system?
Perhaps or perhaps not.
We need some more info:
Is your Win 11 installed in MBR/Legacy/Bios mode?
Did you install EndeavourOS also in MBR mode? If so where did you choose to install Grub’s bootloader?
Post the output of:
test -d /sys/firmware/efi && echo UEFI || echo BIOS
sudo parted -l
cat /etc/fstab
efibootmgr
I’m not sure. I had to reinstall Windows for work stuff, so it blew away the ability to work in Endeavor. So I don’t have access to Endeavor at the moment.
I’m not sure I understand everything so, pardon if I don’t use the right terminology. I have a UEFI, so I don’t believe I installed in Legacy/Bios mode, and maybe not MBR (I thought there was an MBR regardless of bios type, so that sounds like I don’t understand that)
I used the Endeavor Defaults for everything, as that’s what I did last time. Windows wasn’t on the Grub screen when it was done, and I also wasn’t able to choose the windows drive from the UEFI Bios boot options any longer either.
Please use your EnOS live usb and post the output of the commands in my previous post.
[liveuser@eos-2024.06.25 ~]$ test -d /sys/firmware/efi && echo UEFI || echo BIOS
sudo parted -l
cat /etc/fstab
efibootmgr
UEFI
Model: ATA TEAM T253512GB (scsi)
Disk /dev/sda: 512GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system  Name                  Flags
 1      1049kB  630MB   629MB   fat32        EFI System Partition  boot, esp
 2      630MB   1704MB  1074MB  xfs
 3      1704MB  512GB   510GB                                      lvm
Disk /dev/sdb: 512GB
Disk Flags:
 1      2097kB  1076MB  1074MB  fat32           EFI          boot, esp
 2      1076MB  503GB   502GB   ext4            endeavouros
 3      503GB   512GB   9449MB  linux-swap(v1)               swap
Model: ATA WDC WDS500G2B0A (scsi)
Disk /dev/sdc: 500GB
Partition Table: msdos
Disk Flags:
Number  Start   End    Size   Type     File system  Flags
 1      32.8kB  500GB  500GB  primary               boot
Model: ATA ST3000DM007-1WY1 (scsi)
Disk /dev/sdd: 3001GB
Sector size (logical/physical): 512B/4096B
Disk Flags:
 1      17.4kB  16.8MB  16.8MB               Microsoft reserved partition  msftres
 2      16.8MB  3001GB  3001GB  ntfs         Basic data partition          msftdata
Model: General USB Flash Disk (scsi)
Disk /dev/sde: 32.3GB
Disk Flags:
 2      2738MB  2901MB  163MB  primary  fat16        esp
Model: Samsung SSD 990 PRO 2TB (nvme)
Disk /dev/nvme0n1: 2000GB
Disk Flags:
 2      16.8MB  2000GB  2000GB  ntfs         Basic data partition          msftdata
Model: HP SSD EX950 2TB (nvme)
Disk /dev/nvme1n1: 2000GB
Disk Flags:
 1      1049kB  106MB   105MB   fat32        EFI system partition          boot, esp, no_automount
 2      106MB   123MB   16.8MB               Microsoft reserved partition  msftres, no_automount
 3      123MB   2000GB  1999GB  ntfs         Basic data partition          msftdata
 4      2000GB  2000GB  805MB   ntfs                                       hidden, diag, no_automount
# Static information about the filesystems.
# See fstab(5) for details.
# <file system> <dir> <type> <options> <dump> <pass>
BootCurrent: 0003
Timeout: 1 seconds
BootOrder: 0000,0001,0002,0003,0004
Boot0000* Windows Boot Manager  HD(1,GPT,4e7bf4a8-0503-4079-83a1-77b551b6ffca,0x800,0x32000)/\EFI\MICROSOFT\BOOT\BOOTMGFW.EFI57494e444f5753000100000088000000780000004200430044004f0042004a004500430054003d007b00390064006500610038003600320063002d0035006300640064002d0034006500370030002d0061006300630031002d006600330032006200330034003400640034003700390035007d00000033000100000010000000040000007fff0400
Boot0001* RedHat Boot Manager   HD(1,GPT,5e7f1ff6-82f9-452f-94b6-328d60a7a645,0x800,0x12c000)/\EFI\REDHAT\SHIMX64.EFI0000424f
Boot0002* UEFI OS       HD(1,GPT,f2471687-f9c5-435a-8db4-4f3a0011a78d,0x1000,0x200000)/\EFI\BOOT\BOOTX64.EFI0000424f
Boot0003* UEFI: General USB Flash Disk 1100     PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x0)/USB(6,0)/CDROM(1,0x519980,0x4da98)0000424f
Boot0004* UEFI: General USB Flash Disk 1100, Partition 2        PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x0)/USB(6,0)/HD(2,MBR,0xe06d72b0,0x519980,0x4d800)0000424f
I’m gonna bump this in case someone can help, I’d love to reinstall EOS, but want to make sure I have access to both my installs. :slight_smile:
For next time: always always always unplug the WIN HDD when you install on the other drive. I’ve never gone wrong that way. You will have separate boots.
you could unplug endeavour and use MS recovery disk to get yer mbr back right?
2 cents
Looks like to me you have the device as mbr instead of gpt
it looks like boot expects gpt
when using EFI you need GPT and not MBR
Did you choose Systemd-boot in the install or grub?
I have a couple experimental drives in this system, I could probably pull those.
When it comes to the install, I don’t specifically remember which one it was, but it was whatever the default of EOS is.
So my windows drive is under the GPU. :sweat_smile: That is a bit of a herculean task to do this, are there any other suggestions to get the multiboot system, or any resources for it you can suggest?
can you answer this question?
You have a gpt disk but your booting mbr so I suspect you are using legacy boot however it appears you installed for UEFI boot
Of course there are resources for that. I followed https://wiki.archlinux.org/title/Dual_boot_with_Windows
But, honestly, your experimental drive setup looks scary. I do not want to even start reading it, it is too much :smiley:
