falke
April 27, 2024, 2:13pm
1
Hello,
my pc, a 2018 macbook-air, is getting old…
I bought it with a rather minimal configuration, 120 GB Pcie ssd…
I would like to upgrade it with a new SSD, because it’s not that expensive, but I wonder if it’s not the original battery that should be changed first (budget). It’s the original battery, almost 6 years old… it lasts about 4 hours… with wifi surf and bluetooth still active…
Problem, I don’t know if it’s really declined from its nominal state… Would you know of any tools to determine this?
Thanks for your advice.
Translated with DeepL.com (free version)
pebcak
April 27, 2024, 2:27pm
2
One option:
$ upower --enumerate
/org/freedesktop/UPower/devices/battery_BAT1
/org/freedesktop/UPower/devices/line_power_ACAD
/org/freedesktop/UPower/devices/DisplayDevice
and then (for example):
upower --show-info /org/freedesktop/UPower/devices/battery_BAT1
Another option:
$ inxi -aB
falke
April 27, 2024, 2:33pm
3
Thank you pebcak
may I ask you, how you would interprete that result ?
falke@falke-MacBookAir:~$ inxi -aB
Battery:
ID-1: BAT0 charge: 41.7 Wh (100.0%) condition: 41.7/54.3 Wh (76.7%)
volts: 8.5 min: 7.6 model: SMP bq20z451 type: Li-ion serial: N/A
status: Full cycles: 572
pebcak
April 27, 2024, 2:36pm
4
I would think, for being a 6 years old battery, it has still rather good capacity.
76.6% of its initial capacity is not bad.
falke
April 27, 2024, 2:40pm
5
ok, that’s what I supposed…
Same résult here… Somewhat more clear…
alke@falke-MacBookAir:~$ upower --show-info /org/freedesktop/UPower/devices/battery_BAT0
native-path: BAT0
vendor: SMP
model: bq20z451
power supply: yes
updated: sam. 27 avril 2024 16:33:50 (92 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: fully-charged
warning-level: none
energy: 41,6556 Wh
energy-empty: 0 Wh
energy-full: 41,6556 Wh
energy-full-design: 54,34 Wh
energy-rate: 4,1344 W
voltage: 8,529 V
charge-cycles: 572
percentage: 100%
temperature: 32,3 degrees C
capacity: 76,6573%
technology: lithium-ion
icon-name: 'battery-full-charged-symbolic'
In other terms it declined about 25 % in 6 year…
yet I was disappointed with the autonomy when I bought it
So I will either change the SSD
system
Closed
April 29, 2024, 2:41pm
6
