SDDM refuses to log me in. Its logs show nothing out of the ordinary. Happened after an NVIDIA and KDE update.
It will freeze upon entering anything in, X or Wayland.
I use X11 but Wayland doesn’t work either.
Update: I can get a very hacky X session going by manually running startx, kwin, and plasmashell in another TTY.
It’s likely SDDM-related.
It needs more info.
Get info as posted in a similar topic.
https://paste.asterisk.lol/raw/vagoxopora
https://paste.asterisk.lol/raw/etanarocum
Oct 15 16:35:22 sp4c3sh1p systemd[1]: Started Simple Desktop Display Manager.
Oct 15 16:35:24 sp4c3sh1p sddm[1232]: Initializing...
Oct 15 16:35:24 sp4c3sh1p sddm[1232]: Starting...
Oct 15 16:35:24 sp4c3sh1p sddm[1232]: Logind interface found
Oct 15 16:35:24 sp4c3sh1p sddm[1232]: Adding new display...
Oct 15 16:35:24 sp4c3sh1p sddm[1232]: Loaded empty theme configuration
Oct 15 16:35:24 sp4c3sh1p sddm[1232]: Xauthority path: "/run/sddm/xauth_tMFLOO"
Oct 15 16:35:24 sp4c3sh1p sddm[1232]: Using VT 2
Oct 15 16:35:24 sp4c3sh1p sddm[1232]: Display server starting...
Oct 15 16:35:24 sp4c3sh1p sddm[1232]: Writing cookie to "/run/sddm/xauth_tMFLOO"
Oct 15 16:35:24 sp4c3sh1p sddm[1232]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_tMFLOO -noreset -displayfd 16
Oct 15 16:35:30 sp4c3sh1p sddm[1232]: Setting default cursor
Oct 15 16:35:31 sp4c3sh1p sddm[1232]: Running display setup script "/usr/share/sddm/scripts/Xsetup"
Oct 15 16:35:31 sp4c3sh1p sddm[1232]: Display server started.
Oct 15 16:35:31 sp4c3sh1p sddm[1232]: Socket server starting...
Oct 15 16:35:31 sp4c3sh1p sddm[1232]: Socket server started.
Oct 15 16:35:31 sp4c3sh1p sddm[1232]: Loading theme configuration from "/usr/share/sddm/themes/breeze/theme.conf"
Oct 15 16:35:31 sp4c3sh1p sddm[1232]: Greeter starting...
Oct 15 16:35:31 sp4c3sh1p sddm-helper[1455]: [PAM] Starting...
Oct 15 16:35:31 sp4c3sh1p sddm-helper[1455]: [PAM] Authenticating...
Oct 15 16:35:31 sp4c3sh1p sddm-helper[1455]: [PAM] returning.
Oct 15 16:35:31 sp4c3sh1p sddm-helper[1455]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=965) by (uid=0)
Oct 15 16:35:31 sp4c3sh1p sddm-helper[1455]: pam_systemd(sddm-greeter:session): New sd-bus connection (system-bus-pam-systemd-1455) opened.
Oct 15 16:35:31 sp4c3sh1p sddm-helper[1455]: Writing cookie to "/tmp/xauth_kgEDoM"
Oct 15 16:35:31 sp4c3sh1p sddm-helper[1455]: Starting X11 session: "" "/usr/bin/sddm-greeter-qt6 --socket /tmp/sddm-:0-IdlmGo --theme /usr/share/sddm/themes/breeze"
Oct 15 16:35:31 sp4c3sh1p sddm[1232]: Greeter session started successfully
Oct 15 16:35:31 sp4c3sh1p sddm[1232]: Message received from greeter: Connect
Oct 15 16:35:09 sp4c3sh1p kernel: DMAR: [Firmware Bug]: No firmware reserved region can cover this RMRR [0x000000007b000000-0x000000007f7fffff], contact BIOS vendor for fixes
Oct 15 16:35:09 sp4c3sh1p kernel: x86/cpu: SGX disabled by BIOS.
Oct 15 16:35:09 sp4c3sh1p kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
Oct 15 16:35:09 sp4c3sh1p kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 6: ee2000000040110a
Oct 15 16:35:09 sp4c3sh1p kernel: mce: [Hardware Error]: TSC 0 ADDR fef1ffc0 MISC 7880010086
Oct 15 16:35:09 sp4c3sh1p kernel: mce: [Hardware Error]: PROCESSOR 0:906e9 TIME 1729024507 SOCKET 0 APIC 0 microcode f8
Oct 15 16:35:09 sp4c3sh1p kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 7: ee2000000040110a
Oct 15 16:35:09 sp4c3sh1p kernel: mce: [Hardware Error]: TSC 0 ADDR fef1ce40 MISC 47880010086
Oct 15 16:35:09 sp4c3sh1p kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 8: ee2000000040110a
Oct 15 16:35:09 sp4c3sh1p kernel: mce: [Hardware Error]: TSC 0 ADDR fef1ff40 MISC 7880010086
Oct 15 16:35:09 sp4c3sh1p kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 9: ee2000000040110a
Oct 15 16:35:09 sp4c3sh1p kernel: mce: [Hardware Error]: TSC 0 ADDR fef1ff00 MISC 3880010086
Oct 15 16:35:09 sp4c3sh1p systemd-udevd[299]: /etc/udev/rules.d/51-android.rules:1 Unknown group 'plugdev', ignoring.
Oct 15 16:35:09 sp4c3sh1p systemd-udevd[299]: /etc/udev/rules.d/51-android.rules:1 Invalid key 'symlink'.
Oct 15 16:35:09 sp4c3sh1p systemd-udevd[299]: /etc/udev/rules.d/51-android.rules:2 Unknown group 'adbusers', ignoring.
Oct 15 16:35:10 sp4c3sh1p systemd-cryptsetup[397]: Failed to activate, key file '/crypto_keyfile.bin' missing.
Oct 15 16:35:10 sp4c3sh1p kernel:
Oct 15 16:35:17 sp4c3sh1p systemd-udevd[819]: /etc/udev/rules.d/51-android.rules:1 Invalid key 'symlink'.
Oct 15 16:35:17 sp4c3sh1p systemd-udevd[819]: /usr/lib/udev/rules.d/75-davincipanel.rules:2 Unknown group 'resolve', ignoring.
Oct 15 16:35:20 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 16:35:21 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 16:35:21 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
Oct 15 16:35:22 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 16:35:22 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
Oct 15 16:35:28 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 16:35:28 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
Oct 15 16:35:29 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 16:35:29 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
Oct 15 16:36:31 sp4c3sh1p systemd-coredump[2353]: [🡕] Process 2347 (kwin_x11) of user 1000 dumped core.
Stack trace of thread 2347:
#0 0x00007d041eea53f4 n/a (libc.so.6 + 0x963f4)
#1 0x00007d041ee4c120 raise (libc.so.6 + 0x3d120)
#2 0x00007d041ee334c3 abort (libc.so.6 + 0x244c3)
#3 0x00007d041f4905e8 n/a (libQt6Core.so.6 + 0x905e8)
#4 0x00007d041f491571 _ZNK14QMessageLogger5fatalEPKcz (libQt6Core.so.6 + 0x91571)
#5 0x00007d041fadef8b n/a (libQt6Gui.so.6 + 0xdef8b)
#6 0x00007d041fb8a438 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt6Gui.so.6 + 0x18a438)
#7 0x00007d041f557d5d _ZN23QCoreApplicationPrivate4initEv (libQt6Core.so.6 + 0x157d5d)
#8 0x00007d041fb8a4ce _ZN22QGuiApplicationPrivate4initEv (libQt6Gui.so.6 + 0x18a4ce)
#9 0x00007d04204f95a6 _ZN19QApplicationPrivate4initEv (libQt6Widgets.so.6 + 0xf95a6)
#10 0x00007d042204f365 _ZN4KWin11ApplicationC2ENS0_13OperationModeERiPPc (libkwin.so.6 + 0x24f365)
#11 0x00005a0e28645b13 n/a (kwin_x11 + 0x39b13)
#12 0x00007d041ee34e08 n/a (libc.so.6 + 0x25e08)
#13 0x00007d041ee34ecc __libc_start_main (libc.so.6 + 0x25ecc)
#14 0x00005a0e28649dd5 n/a (kwin_x11 + 0x3ddd5)
Stack trace of thread 2348:
#0 0x00007d041ef1abb0 ppoll (libc.so.6 + 0x10bbb0)
#1 0x00007d041e170227 n/a (libglib-2.0.so.0 + 0xc0227)
#2 0x00007d041e10ca55 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca55)
#3 0x00007d041f7bf71d _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3bf71d)
#4 0x00007d041f564566 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x164566)
#5 0x00007d041f657072 _ZN7QThread4execEv (libQt6Core.so.6 + 0x257072)
empty
[Autologin]
Relogin=false
Session=plasma
User=
[General]
HaltCommand=/usr/bin/systemctl poweroff
RebootCommand=/usr/bin/systemctl reboot
[Theme]
Current=breeze
[Users]
MaximumUid=60513
MinimumUid=1000
empty
It looks like a kWin crash, not SDDM. Several KDE packages were updated, so it may be some bug in one or more of them.
I would try a different kernel.
KWin works when called from my hacky X session, do you mean to use the fallback initramfs?
Not really, but you could try. I meant linux or linux-lts.
You are right, but it’s kwin that crashes, and no SDDM bad behavior in the logs. Maybe a combination of things make kwin to crash. I don’t know, just guessing, after your reported info
Nope, linux gives the same issue.
Oct 15 19:22:48 sp4c3sh1p kernel: DMAR: [Firmware Bug]: No firmware reserved region can cover this RMRR [0x000000007b000000-0x000000007f7fffff], contact BIOS vendor for fixes
Oct 15 19:22:48 sp4c3sh1p kernel: x86/cpu: SGX disabled by BIOS.
Oct 15 19:22:48 sp4c3sh1p kernel: tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
Oct 15 19:22:48 sp4c3sh1p kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 6: ee0000000040110a
Oct 15 19:22:48 sp4c3sh1p kernel: mce: [Hardware Error]: TSC 0 ADDR fef1ffc0 MISC 7880010086
Oct 15 19:22:48 sp4c3sh1p kernel: mce: [Hardware Error]: PROCESSOR 0:906e9 TIME 1729034566 SOCKET 0 APIC 0 microcode f8
Oct 15 19:22:48 sp4c3sh1p kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 7: ee0000000040110a
Oct 15 19:22:48 sp4c3sh1p kernel: mce: [Hardware Error]: TSC 0 ADDR fef1ce40 MISC 47880010086
Oct 15 19:22:48 sp4c3sh1p kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 8: ee0000000040110a
Oct 15 19:22:48 sp4c3sh1p kernel: mce: [Hardware Error]: TSC 0 ADDR fef1ff40 MISC 7880010086
Oct 15 19:22:48 sp4c3sh1p kernel: mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 9: ee0000000040110a
Oct 15 19:22:48 sp4c3sh1p kernel: mce: [Hardware Error]: TSC 0 ADDR fef1ff00 MISC 3880010086
Oct 15 19:22:49 sp4c3sh1p systemd-udevd[301]: /etc/udev/rules.d/51-android.rules:1 Unknown group 'plugdev', ignoring.
Oct 15 19:22:49 sp4c3sh1p systemd-udevd[301]: /etc/udev/rules.d/51-android.rules:1 Invalid key 'symlink'.
Oct 15 19:22:49 sp4c3sh1p systemd-udevd[301]: /etc/udev/rules.d/51-android.rules:2 Unknown group 'adbusers', ignoring.
Oct 15 19:22:49 sp4c3sh1p kernel:
Oct 15 19:22:49 sp4c3sh1p systemd-cryptsetup[404]: Failed to activate, key file '/crypto_keyfile.bin' missing.
Oct 15 19:22:51 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 19:22:52 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 19:22:52 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
Oct 15 19:22:53 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 19:22:53 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
Oct 15 19:22:55 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 19:22:55 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
Oct 15 19:22:56 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 19:22:56 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
Oct 15 19:23:10 sp4c3sh1p systemd-udevd[1021]: /etc/udev/rules.d/51-android.rules:1 Invalid key 'symlink'.
Oct 15 19:23:10 sp4c3sh1p systemd-udevd[1021]: /usr/lib/udev/rules.d/75-davincipanel.rules:2 Unknown group 'resolve', ignoring.
Oct 15 19:23:20 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 19:23:20 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
Oct 15 19:23:21 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 19:23:21 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
Oct 15 19:23:54 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 19:23:54 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
Oct 15 19:23:55 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 19:23:55 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
Oct 15 19:24:05 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 19:24:05 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
Oct 15 19:24:11 sp4c3sh1p kaccess[2453]: Couldn't start kglobalaccel from org.kde.kglobalaccel.service: QDBusError("org.freedesktop.DBus.Error.ServiceUnknown", "The name is not activatable")
Oct 15 19:24:11 sp4c3sh1p plasmashell[2454]: Couldn't start kglobalaccel from org.kde.kglobalaccel.service: QDBusError("org.freedesktop.DBus.Error.ServiceUnknown", "The name is not activatable")
Oct 15 19:24:14 sp4c3sh1p kactivitymanagerd[2535]: Couldn't start kglobalaccel from org.kde.kglobalaccel.service: QDBusError("org.freedesktop.DBus.Error.ServiceUnknown", "The name is not activatable")
Oct 15 19:24:16 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 19:24:16 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
Oct 15 19:24:18 sp4c3sh1p plasmashell[2454]: "applications.menu" not found in QList("/home/ast3risk/.config/menus", "/etc/xdg/menus")
Oct 15 19:24:30 sp4c3sh1p plasmashell[2454]: "applications.menu" not found in QList("/home/ast3risk/.config/menus", "/etc/xdg/menus")
Oct 15 19:24:42 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 19:24:42 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
Oct 15 19:24:43 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 19:24:43 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
Oct 15 19:25:09 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 19:25:09 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
Oct 15 19:25:10 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 19:25:10 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
Oct 15 19:25:36 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
Oct 15 19:25:36 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* LSPCON init failed on port B
Oct 15 19:25:37 sp4c3sh1p kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to probe lspcon
@petsam I somehow fixed it.
Update: You only need to change to another TTY (Ctrl+Alt+F4, you can replace F4 with any function key besides F1 and F2) and remove the EndeavourOS SDDM configs.
sudo pacman -R eos-plasma-sddm-config
If you don’t want to remove that package, follow the instructions here: I'm running Plasma with sddm. After updating I can't login - #20 by Viera
sudo pacman -R sddm sddm-kcm eos-plasma-sddm-config
Reinstall SDDM (not the configs):
sudo pacman -S sddm sddm-kcm
Re-enable SDDM and reboot
sudo systemctl enable sddm
SDDM will revert to its default LXQt-style look if you remove the package, but it actually works now.
So it was SDDM. I was right ![]()
Too soon for a victory. ![]()
SDDM has not been updated since March 6, 2024.
OTOH kwin and other packages have been updated today, yesterday or some days before.
Does it make sense? ![]()
Actually, sddm-kcm (kde utility) was also updated today (Oct 15)… ![]()
or was it the endeavouros configs? ![]()
I can confirm that removing only eos-plasma-sddm-config fixes it (as in, it disables the log in screen theme which at this point seems to be the issue), and reinstalling it triggers the bug again
From what I could read, this package installs two files, that look harmless, unless something has changed upstream.
Could you share your current config, to compare to eos files?
for Xconf in /etc/sddm.conf.d/*.conf /usr/share/sddm/themes/breeze/*.conf.user ; do echo -e "\n### $Xconf" ; cat "$Xconf"; done
If you don’t mind some testing, while in your KDE session:
eos-plasma-sddm-config in a terminalOr do nothing and let EnOS devs to do their stuff ![]()
Yeah I also checked the repo, answered in the other thread at I'm running Plasma with sddm. After updating I can't login - #20 by Viera
Yes, I was just reading it ![]()
It seems it’s a Plasma/KDE change IMO. Edit: Probably sddm-kcm. I don’t have it installed. I bet the issue could be solved if sddm-kcm was removed.
IMHO EnOS should not interfere with KDE default settings (file kde_settings.conf), rather adding another drop-in file, as it is designed. That file is modified by sddm-kcm. I am not sure if sddm-kcm also reads all other config files, but it should.
Something is wrong in KDE-dev-land.
Having sddm start in X11 should not break KDE session in any way.
I am not on KDE to do a normal test, although I use SDDM (in X11) with no issues (bspwm). ![]()
So, I did a fresh install of Endeavour and after allowing it to update, I cannot log into KDE with an external monitor attached to my laptops HDMI port. I get this same issue. Removing that config file did allow me to bypass the issue, but this is happening now right after a fresh install.
Well a fresh install would add that package back, you should make a fresh post with your issue.
Following this thread I can confirm that manually editing that config file did the trick for me.
