IMY issue is referred to the sddm-helper (Actually, I use Gnome on wayland)…
sddm-helper[1171]: gkr-pam: unable to locate daemon control file
I’ve found this therad on the arch forum (reffered to the sddm-password) but before doing commands that I’mnot able to reset I would know if this is the correct way to solve it.
I started to experience a non-reading theme for sddm days ago. In the config file it seems to be everything good.
Basically it runs using the default vanilla theme. I can log in without problems but sometime it log out without any reason.
I also tried to set lightdm just to get a try, but it seem to lock the mouse functionality, so I need to restart and set again sddm, using it with this little issue.
Anyone knows why this behaviour from it?
Was change something in some update?
