SDDM and hidpi.conf
On EndeavourOS with Plasma Desktop SDDM doesn’t have hidpi enabled by default. This means that you have to create file hidpi.conf into /etc/sddm.conf.d/ with these settings to get it work correctly:
[Wayland]
EnableHiDPI=true
[X11]
EnableHiDPI=true
And if using Wayland, add this to the end of .conf file you created:
[General]
GreeterEnvironment=QT_SCREEN_SCALE_FACTORS=2,QT_FONT_DPI=192
Be noted, that on QT_SCREEN_SCALE_FACTORS number defining scale factor MUST be in in form 1, 1.75, 2 etc. and NOT in hundreds like 175, because this creates greeter in colossal size that’s unusable.
Hope this helps. :slightly_smiling_face:
And if I have messed up something, give me heads up so I’ll fix it here. :slightly_smiling_face:
Anyone tested this ?
Me :grin:
At least on my machine it works. :slight_smile:
I am using this config (with the right values for me) for a few months now.
Also this for the fonts in grub.
I’m using this as @Dinomonster described and it works perfect for my laptop.
It should be noted that without the HiDPI.conf, the system applies the Hi-DPI settings from the system for subsequent screen lock/unlock sleep/wake instances (at least on mine), but adding the HiDPI.conf file forces those settings for the first login after restart…which is nice.
Thanks!
For what screen resolution ? i have 2560x1440
Scale is defined by these. :slight_smile:
Yes so which one would fit best ? Is there a way to fast test this ?
I have nearly same resolution as you and use 1.75 and that “default” DPI.
I don´t see any difference, i just rebooted with the settings posted in post 1. :sweat_smile:
Edit: It’s only for the login screen ? i boot my OS without login screen.
