I have a screen that could work on an usb-c, when I plug it into one of the two usb-c I have the screen stay black, and if I pop the built-in menu on the screen, the message “usb-c no signal” appear.
Here is my config:
Operating System: EndeavourOS
KDE Plasma Version: 6.3.5
KDE Frameworks Version: 6.14.0
Qt Version: 6.9.0
Kernel Version: 6.14.6-arch1-1 (64-bit)
Graphics Platform: Wayland
Processors: 20 × 13th Gen Intel® Core™ i7-13700H
Memory: 15,4 GiB of RAM
Graphics Processor: Intel® Iris® Xe Graphics
Manufacturer: TUXEDO
Product Name: TUXEDO InfinityBook Pro Gen8 (MK1)
The log when I plug the usb-c and make the built-in menu appear:
❯ sudo dmesg -W
<<<<<< the usb-c is plugged here >>>>>>
[227370.305348] usb usb2-port1: attempt power cycle
[227378.762088] usb usb2-port1: unable to enumerate USB device
<<<<<< the menu is triger here >>>>>>
[227398.885600] usb 3-2: new high-speed USB device number 21 using xhci_hcd
[227399.012705] usb 3-2: New USB device found, idVendor=2109, idProduct=2211, bcdDevice=6a.73
[227399.012719] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[227399.012723] usb 3-2: Product: USB2.0 Hub
[227399.012727] usb 3-2: Manufacturer: VIA Labs, Inc.
[227399.012729] usb 3-2: SerialNumber: 0000RBLMHK000532
[227399.016112] hub 3-2:1.0: USB hub found
[227399.016344] hub 3-2:1.0: 5 ports detected
[227399.553721] usb 3-2.1: new full-speed USB device number 22 using xhci_hcd
[227399.643114] usb 3-2.1: New USB device found, idVendor=2d1f, idProduct=0156, bcdDevice=18.03
[227399.643122] usb 3-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[227399.643125] usb 3-2.1: Product: ISD-V4
[227399.643126] usb 3-2.1: Manufacturer: Tablet
[227399.650451] input: Tablet ISD-V4 Stylus as /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2.1/3-2.1:1.0/0003:2D1F:0156.002D/input/input108
[227399.650834] input: Tablet ISD-V4 as /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2.1/3-2.1:1.0/0003:2D1F:0156.002D/input/input109
[227399.651216] hid-generic 0003:2D1F:0156.002D: input,hiddev96,hidraw3: USB HID v1.10 Device [Tablet ISD-V4] on usb-0000:00:14.0-2.1/input0
[227399.727714] usb 3-2.2: new full-speed USB device number 23 using xhci_hcd
[227399.813903] usb 3-2.2: New USB device found, idVendor=2575, idProduct=0915, bcdDevice=31.00
[227399.813910] usb 3-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[227399.813912] usb 3-2.2: Product: CoolTouch® System
[227399.813914] usb 3-2.2: Manufacturer: Weida Hi-Tech
[227399.820605] input: Weida Hi-Tech CoolTouch® System as /devices/pci0000:00/0000:00:14.0/usb3/3-2/3-2.2/3-2.2:1.0/0003:2575:0915.002E/input/input111
[227399.820787] hid-multitouch 0003:2575:0915.002E: input,hidraw4: USB HID v1.10 Device [Weida Hi-Tech CoolTouch® System] on usb-0000:00:14.0-2.2/input0
[227399.897591] usb 3-2.4: new full-speed USB device number 24 using xhci_hcd
[227399.999198] usb 3-2.4: not running at top speed; connect to a high speed hub
[227400.003342] usb 3-2.4: New USB device found, idVendor=2109, idProduct=0103, bcdDevice= 2.06
[227400.003364] usb 3-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[227400.003373] usb 3-2.4: Product: USB 2.0 BILLBOARD
[227400.003381] usb 3-2.4: Manufacturer: VLI Inc.
[227400.003388] usb 3-2.4: SerialNumber: 0000000000000001
[227400.076641] usb 3-2.5: new high-speed USB device number 25 using xhci_hcd
[227400.152988] usb 3-2.5: New USB device found, idVendor=0b05, idProduct=19c1, bcdDevice= 0.01
[227400.153002] usb 3-2.5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[227400.155771] hid-generic 0003:0B05:19C1.002F: unsupported Resolution Multiplier 0
[227400.156151] hid-generic 0003:0B05:19C1.002F: hiddev97,hidraw5: USB HID v1.10 Device [HID 0b05:19c1] on usb-0000:00:14.0-2.5/input0
When I let the usb plug in I have these errors:
[228102.106433] usb 3-4-port2: Cannot enable. Maybe the USB cable is bad?
[228102.106608] usb 3-4-port2: cannot disable (err = -71)
[228102.106803] usb 3-4-port2: cannot reset (err = -71)
[228102.107187] usb 3-4-port2: cannot reset (err = -71)
[228102.107345] usb 3-4-port2: cannot reset (err = -71)
[228102.107514] usb 3-4-port2: cannot reset (err = -71)
[228102.107682] usb 3-4-port2: cannot reset (err = -71)
[228102.107686] usb 3-4-port2: Cannot enable. Maybe the USB cable is bad?
[228102.108028] usb 3-4-port2: cannot disable (err = -71)
[228102.108201] usb 3-4-port2: cannot disable (err = -71)
[228102.108365] hub 3-4:1.0: hub_ext_port_status failed (err = -71)
[228102.108531] hub 3-4:1.0: hub_ext_port_status failed (err = -71)
[228111.739373] usb 3-4.1: USB disconnect, device number 37
[228111.791877] usb 3-4.2: USB disconnect, device number 38
[228111.832924] usb 3-4.4: USB disconnect, device number 39
[228111.833377] usb 3-4.5: USB disconnect, device number 40
[228111.948200] usb 3-4: reset high-speed USB device number 36 using xhci_hcd
[228112.062003] usb 3-4: device descriptor read/64, error -71
[228112.275064] usb 3-4: device descriptor read/64, error -71
[228113.122253] usb 3-4: USB disconnect, device number 36
So I try with another usb-c, both on the two usb port but nothing change.
Another information from eos-log-tool:
❯ cat $HOME/eos-log-tool.logs
#################### lspci -vnn ########################
00:00.0 Host bridge [0600]: Intel Corporation Raptor Lake-P 6p+8e cores Host Bridge/DRAM Controller [8086:a706]
DeviceName: Onboard - Other
Subsystem: AIstone Global Limited Device [1d05:124a]
Flags: bus master, fast devsel, latency 0, IOMMU group 1
Capabilities: <access denied>
Kernel driver in use: igen6_edac
Kernel modules: igen6_edac
00:02.0 VGA compatible controller [0300]: Intel Corporation Raptor Lake-P [Iris Xe Graphics] [8086:a7a0] (rev 04) (prog-if 00 [VGA controller])
DeviceName: Onboard - Video
Flags: bus master, fast devsel, latency 0, IRQ 193, IOMMU group 0
Memory at 601c000000 (64-bit, non-prefetchable) [size=16M]
Memory at 4000000000 (64-bit, prefetchable) [size=256M]
I/O ports at 3000 [size=64]
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Kernel driver in use: i915
Kernel modules: i915, xe
00:06.0 PCI bridge [0604]: Intel Corporation Raptor Lake PCIe 4.0 Graphics Port [8086:a74d] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 122, IOMMU group 2
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: [disabled] [16-bit]
Memory behind bridge: 82400000-824fffff [size=1M] [32-bit]
Prefetchable memory behind bridge: [disabled] [64-bit]
Kernel driver in use: pcieport
00:06.2 PCI bridge [0604]: Intel Corporation Device [8086:a73d] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 123, IOMMU group 3
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
Memory behind bridge: 82300000-823fffff [size=1M] [32-bit]
00:07.0 PCI bridge [0604]: Intel Corporation Raptor Lake-P Thunderbolt 4 PCI Express Root Port #0 [8086:a76e] (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 124, IOMMU group 4
Bus: primary=00, secondary=03, subordinate=2c, sec-latency=0
I/O behind bridge: 4000-4fff [size=4K] [16-bit]
Memory behind bridge: 76000000-821fffff [size=194M] [32-bit]
Prefetchable memory behind bridge: 6000000000-601bffffff [size=448M] [32-bit]
00:08.0 System peripheral [0880]: Intel Corporation GNA Scoring Accelerator module [8086:a74f]
Flags: fast devsel, IRQ 255, IOMMU group 5
Memory at 601d181000 (64-bit, non-prefetchable) [disabled] [size=4K]
00:0a.0 Signal processing controller [1180]: Intel Corporation Raptor Lake Crashlog and Telemetry [8086:a77d] (rev 01)
Flags: fast devsel, IOMMU group 6
Memory at 601d160000 (64-bit, non-prefetchable) [size=32K]
Kernel driver in use: intel_vsec
Kernel modules: intel_vsec
00:0d.0 USB controller [0c03]: Intel Corporation Raptor Lake-P Thunderbolt 4 USB Controller [8086:a71e] (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 125, IOMMU group 7
Memory at 601d150000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
00:0d.2 USB controller [0c03]: Intel Corporation Raptor Lake-P Thunderbolt 4 NHI #0 [8086:a73e] (prog-if 40 [USB4 Host Interface])
Subsystem: Device [2222:1111]
Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 7
Memory at 601d100000 (64-bit, non-prefetchable) [size=256K]
Memory at 601d180000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: thunderbolt
Kernel modules: thunderbolt
00:14.0 USB controller [0c03]: Intel Corporation Alder Lake PCH USB 3.2 xHCI Host Controller [8086:51ed] (rev 01) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 133, IOMMU group 8
Memory at 601d140000 (64-bit, non-prefetchable) [size=64K]
00:14.2 RAM memory [0500]: Intel Corporation Alder Lake PCH Shared SRAM [8086:51ef] (rev 01)
Flags: fast devsel, IOMMU group 8
Memory at 601d178000 (64-bit, non-prefetchable) [disabled] [size=16K]
Memory at 601d17f000 (64-bit, non-prefetchable) [disabled] [size=4K]
00:14.3 Network controller [0280]: Intel Corporation Raptor Lake PCH CNVi WiFi [8086:51f1] (rev 01)
DeviceName: Onboard - Ethernet
Subsystem: Intel Corporation Device [8086:0074]
Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 9
Memory at 601d174000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
00:15.0 Serial bus controller [0c80]: Intel Corporation Alder Lake PCH Serial IO I2C Controller #0 [8086:51e8] (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 27, IOMMU group 10
Memory at 4017000000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:16.0 Communication controller [0780]: Intel Corporation Alder Lake PCH HECI Controller [8086:51e0] (rev 01)
Flags: bus master, fast devsel, latency 0, IRQ 141, IOMMU group 11
Memory at 601d17d000 (64-bit, non-prefetchable) [size=4K]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1f.0 ISA bridge [0601]: Intel Corporation Raptor Lake LPC/eSPI Controller [8086:519d] (rev 01)
Flags: bus master, fast devsel, latency 0, IOMMU group 12
00:1f.3 Audio device [0403]: Intel Corporation Raptor Lake-P/U/H cAVS [8086:51ca] (rev 01) (prog-if 80)
DeviceName: Onboard - Sound
Subsystem: AIstone Global Limited Device [1d05:124b]
Flags: bus master, fast devsel, latency 32, IRQ 16, IOMMU group 12
Memory at 601d170000 (64-bit, non-prefetchable) [size=16K]
Memory at 601d000000 (64-bit, non-prefetchable) [size=1M]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl
00:1f.4 SMBus [0c05]: Intel Corporation Alder Lake PCH-P SMBus Host Controller [8086:51a3] (rev 01)
Flags: medium devsel, IRQ 16, IOMMU group 12
Memory at 601d17c000 (64-bit, non-prefetchable) [size=256]
I/O ports at efa0 [size=32]
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller [0c80]: Intel Corporation Alder Lake-P PCH SPI Controller [8086:51a4] (rev 01)
Flags: fast devsel, IOMMU group 12
Memory at 74400000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: intel-spi
Kernel modules: spi_intel_pci
01:00.0 Non-Volatile memory controller [0108]: Kingston Technology Company, Inc. NV1 NVMe SSD [SM2263XT] (DRAM-less) [2646:500f] (rev 03) (prog-if 02 [NVM Express])
Subsystem: Kingston Technology Company, Inc. NV1 NVMe SSD [SM2263XT] (DRAM-less) [2646:500f]
Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 13
Memory at 82400000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: nvme
Kernel modules: nvme
02:00.0 Non-Volatile memory controller [0108]: Kingston Technology Company, Inc. NV1 NVMe SSD [SM2263XT] (DRAM-less) [2646:500f] (rev 03) (prog-if 02 [NVM Express])
Flags: bus master, fast devsel, latency 0, IRQ 16, IOMMU group 14
Memory at 82300000 (64-bit, non-prefetchable) [size=16K]
#################### lsusb ########################
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 2b7e:c757 SunplusIT Inc FHD Webcam
Bus 003 Device 003: ID 8087:0026 Intel Corp. AX201 Bluetooth
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
