Screen Tearing after System Update
Hi
I updated my System yesterday after a month and now I encounter my screen tearing and flickering after a few minutes of Startup. I am using the i3 version of Endeavour OS.
I have tried reducing the Refresh Rate and creating my own modelines but the problem still persists. Below I am adding my neofetch and xrandr output.
Any help is appreciated.
inxi -Gaz would be interesting to see…
And very welcome here :enos:
Lets see if we can fix this fast!
Also
pacman -Qs xf86-video
would be interesting.
user gone back to windows :wink:
Hi there!
Thank you for the quick replies. I was caught up in Schoolwork.
I executed both commands:
inxi -Gaz:
pacman -Qs xf68-video
Thank you for helping!
At least you shouldn’t need xf86-video-ati, so feel free to uninstall it.
I did that a minute ago and rebooted.
The issue still persists sadly.
Thank you for your time.
Does the problem occur also with the LTS kernel?
If not, then it can be a glitch of the default kernel, and a fix may be coming after some time, provided someone has reported this to the kernel devs.
I don’t really know how to switch Kernels. I googled it but I’m afraid if the instructions apply to Endeavour. Is there an easy way to do it on endeavour?
sudo pacman -Syu linux-lts linux-lts-headers
…and reboot.
:v:
could be also picom is an issue… i can not use the default package here … but i am running older AMD radeon card…
local/picom-tryone-git 1851_Next.570.gcee1287_2023.01.29-1
    tryone144's picom fork with dual_kawase blur, an X compositor (fork of compton)
and still no clue if it is running on the igpu ?
looks like an art gallery to me Cezanne and Renoir are both Impressionist ? :wink:
Cezanne is the codename of AMD’s Ryzen 5000 series of mobile and desktop APUs based on the Zen 3 CPU and Vega GPU microarchitectures succeeding the Ryzen 4000 “Renoir” series.
Hey all!
Thank you so much for your help. It turned out to be a picom issue. I disabled it (for now) and everything is working perfectly again. I am so sorry for wasting your time with a silly issue! Should’ve been my first or second thought. Thank you so much for your help :slight_smile:
you where nmot wasting tiome… and issue is not really solved :wink:
If it works without picom you may have the same issue as i do have here… you can try using alternative picom version like i do… but indeewd if yoiu do not mind transparfency… you can go without this
When I have time I will look at your alternative picom but for now im just happy to be able to use my laptop again :smile:
