Hello, Im new to linux I installed the x11 Kde plasma version of EndeavourOs and after i installed my screen resolutions are not fully showing the one its on right now is 1024x768 and my screen is normally 1440x900 anyway to fix it? ( I use amd btw )
Welcome @Mohammed
Can you share your hardware details please, to help us see what the issue might be:
inxi -Fxxc0z | eos-sendlog
here it is
Kernel: 6.9.8-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A wm: kwin_x11 dm: 1: LightDM
note: stopped 2: SDDM Distro: EndeavourOS base: Arch Linux
Type: Desktop System: ASUSTeK product: CM6630_CM6730_CM6830. v: N/A
serial:
Mobo: ASUSTeK model: CM6330_CM6630_CM6730_CM6830 v: Rev x.0x
serial: part-nu: SKU BIOS: American Megatrends v: 3602
date: 02/20/2012
Info: quad core model: Intel Core i5-2320 bits: 64 type: MCP
arch: Sandy Bridge rev: 7 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
Speed (MHz): avg: 1599 high: 1600 min/max: 1600/3300 cores: 1: 1600
2: 1600 3: 1600 4: 1596 bogomips: 23955
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: ASUSTeK driver: i915 v: kernel arch: Gen-6 ports: active: none
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0102
Device-2: AMD Oland [Radeon HD 8570 / R5 430 OEM R7 240/340 Radeon 520
OEM] vendor: Dell driver: radeon v: kernel arch: GCN-1 pcie: speed: 5 GT/s
lanes: 8 ports: active: DVI-I-1 empty: DP-3 bus-ID: 01:00.0
chip-ID: 1002:6611 temp: 43.0 C
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: modesetting,radeon
alternate: fbdev,intel,vesa dri: radeonsi,crocus gpu: radeon
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1024x768 s-dpi: 96
Monitor-1: DVI-I-1 mapped: DVI-0 res: 1024x768 size: N/A
API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: crocus
device: 2 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
drv: radeonsi inactive: wayland
API: OpenGL v: 4.5 compat-v: 3.3 vendor: amd mesa v: 24.1.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: OLAND (radeonsi LLVM 18.1.8 DRM
2.50 6.9.8-arch1-1) device-ID: 1002:6611
Device-1: Intel 6 Series/C200 Series Family High Definition Audio
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series] vendor: Dell driver: snd_hda_intel v: kernel pcie: speed: 5 GT/s
lanes: 8 bus-ID: 01:00.1 chip-ID: 1002:aab0
API: ALSA v: k6.9.8-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin
Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel pcie:
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
IF: enp3s0 state: down mac:
Device-2: Ralink RT5370 Wireless Adapter driver: rt2800usb type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 3-2:2 chip-ID: 148f:5370
IF: wlan0 state: up mac:
Local Storage: total: 465.77 GiB used: 194.36 GiB (41.7%)
ID-1: /dev/sdb vendor: Western Digital model: WD2500AAJS-00VTA0
size: 232.88 GiB speed: 3.0 Gb/s serial:
ID-2: /dev/sdc vendor: Western Digital model: WD2500AAJS-60M0A1
size: 232.89 GiB speed: 3.0 Gb/s serial:
ID-1: / size: 47.76 GiB used: 17.25 GiB (36.1%) fs: ext4 dev: /dev/sdb2
System Temperatures: cpu: 44.0 C mobo: N/A gpu: radeon temp: 43.0 C
Fan Speeds (rpm): N/A
Memory: total: 8 GiB available: 7.66 GiB used: 1.88 GiB (24.6%)
Processes: 201 Power: uptime: 24m wakeups: 0 Init: systemd v: 256
default: graphical
Packages: pm: pacman pkgs: 1286 Compilers: gcc: 14.1.1 Shell: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.35
Can you share the output of:
xrandr
That’ll output your display outputs, including preferred and current.
Screen 0: minimum 320 x 200, current 1024 x 768, maximum 16384 x 16384
DisplayPort-2 disconnected (normal left inverted right x axis y axis)
DVI-0 connected primary 1024x768+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
1024x768 60.00*
800x600 60.32 56.25
848x480 60.00
640x480 59.94
VGA-1-1 disconnected (normal left inverted right x axis y axis)
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
DP-1-1 disconnected (normal left inverted right x axis y axis)
HDMI-1-2 disconnected (normal left inverted right x axis y axis)
DP-1-2 disconnected (normal left inverted right x axis y axis)
Are you there?
I did wait a bit, but a guy’s gotta sleep
At the moment the only thing that’s really telling me, is it hasn’t correctly detected your monitor’s capabilities, which is perhaps obvious at this point.
Does your screen support HDMI or DisplayPort and are you able to connect it via that?
DVI is an older standard that can be a bit more finicky, particularly as the standard bridged analogue and digital with the various connectors/leads and such. The current behaviour seems typical of an analogue connection.
My screen only has a vga port, on the other hand my graphics card has a dvi and a display port so i used a dvi to vga adapter and connected a vga caple to it and to the monitor
I’ve not tried this, but the same tool could be used. Maybe something like:
xrandr --output DVI-0 --mode 1440x900
You might also include --rate xx
in that command, replacing xx
with your monitors supported refresh rate.
Does this run when the pc runs or do i have to run it everytime when my pc starts and is there a way to make it run with the pc?
I found a solution to the issue all i have to do is use cvt 1440 900 and cope a line of code it will give me and use xrandr to make a new mode with xrandr --newmode and after it the line of code i copyed the add the mode to my screen which is dvi-0 and it will be in the settings
