Hi everyone,
Since I’ve installed Endeavour OS (Gnome), I notice that my PC now freezes almost every-time I switch between Wi-fi and Ethernet or if I’m disconnected from the internet, etc. Since I have a rather unstable network, it’s quite annoying. But I haven’t found any post showing similar problem so I’m stuck.
Here’s the
sudo journalctl -b -1 | eos-sendlog
http://ix.io/4wPg
Thank you guys !
I’ll up this one cause I’m still having this problem and cannot find similar problem.
More recent sudo journalctl -b -1 | eos-sendlog
http://ix.io/4BWI
To describe the freeze more accurately, it is a little bit different than a ‘regular’ freeze where everything stops, because everything else from the screen seems to still be working fine. I can still hear my clicks being made in game for eg., audio is fine, I can still type and when the freeze stops it will have been typed correctly, etc.
So I suppose this could lead to a GPU related problem ? Although it always happen when I change connexion, I suspect it also happens in other circonstances, seemingly random. I might be wrong tho.
Again, thanks a lot !
post your hardware inxi -FAZ --no-host | eos-sendlog
this too sudo dmesg -rl warn,err,crit
Forgot to mention to post dmesg when the system actually froze, you could do this if the screen is frozen by switching to console with ctrl + alt + f3
, if that doesn’t work you can do this through ssh (you can enable ssh in the gnome settings). Not sure how to post dmesg from previous boots.
http://ix.io/4BXf
Résumé
<3>[ 0.125108] x86/cpu: SGX disabled by BIOS.
<4>[ 0.158626] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
<4>[ 0.158626] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
<4>[ 0.158672] #5 #6 #7
<4>[ 0.165605] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
<3>[ 0.340286] platform MSFT0101:00: failed to claim resource 1: [mem 0xfed40000-0xfed40fff]
<3>[ 0.340295] acpi MSFT0101:00: platform device creation failed: -16
<4>[ 0.420098] tpm_crb MSFT0101:00: [Firmware Bug]: Bad ACPI memory layout
<4>[ 0.454974] resource: resource sanity check: requesting [mem 0x00000000fdffe800-0x00000000fe0007ff], which spans more than pnp 00:00 [mem 0xfdb00000-0xfdffffff]
<4>[ 0.454977] caller pmc_core_probe+0xd6/0x560 mapping multiple BARs
<4>[ 1.543019] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
<4>[ 1.543039] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
<4>[ 1.543056] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
<4>[ 1.543072] wmi_bus wmi_bus-PNP0C14:01: WQ data block query control method not found
<4>[ 1.551492] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
<4>[ 1.631907] usb: port power management may be unreliable
<4>[ 2.653294] memfd_create() without MFD_EXEC nor MFD_NOEXEC_SEAL, pid=1 'systemd'
<4>[ 4.994449] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
<4>[ 5.535666] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
<4>[ 31.555096] acer_wmi: Unknown function number - 6 - 1
<4>[ 395.660481] warning: `ThreadPoolForeg' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
<4>[ 2124.112472] ath10k_pci 0000:02:00.0: failed to install key for vdev 0 peer 30:d3:2d:7c:a1:3f: -110
<3>[ 2124.112492] wlan0: failed to remove key (0, 30:d3:2d:7c:a1:3f) from hardware (-110)
<4>[ 3318.895139] pcieport 0000:04:00.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Receiver ID)
<4>[ 3318.895142] pcieport 0000:04:00.0: device [8086:15da] error status/mask=00002080/00002000
<4>[ 3318.895145] pcieport 0000:04:00.0: [ 7] BadDLLP
<3>[ 3318.920717] xhci_hcd 0000:3c:00.0: Unable to change power state from D3hot to D0, device inaccessible
<3>[ 3318.980693] xhci_hcd 0000:3c:00.0: Unable to change power state from D3cold to D0, device inaccessible
<4>[ 3318.980708] xhci_hcd 0000:3c:00.0: Controller not ready at resume -19
<3>[ 3318.980710] xhci_hcd 0000:3c:00.0: PCI post-resume error -19!
<3>[ 3318.980711] xhci_hcd 0000:3c:00.0: HC died; cleaning up
<4>[ 3318.981106] xhci_hcd 0000:3c:00.0: Host halt failed, -19
<4>[ 3318.981109] xhci_hcd 0000:3c:00.0: Host not accessible, reset failed.
<4>[ 3323.900284] pcieport 0000:00:1c.4: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
<4>[ 3323.900290] pcieport 0000:00:1c.4: device [8086:a114] error status/mask=00002001/00002000
<4>[ 3323.900298] pcieport 0000:00:1c.4: [ 0] RxErr (First)
<3>[ 3323.975918] pcieport 0000:05:00.0: Unable to change power state from D3hot to D0, device inaccessible
<3>[ 3344.327393] Bluetooth: hci0: SCO packet for unknown connection handle 5
<3>[ 3344.327413] Bluetooth: hci0: SCO packet for unknown connection handle 5
<4>[11204.325160] acer_wmi: Unknown function number - 6 - 1
<4>[11254.114890] acer_wmi: Unknown function number - 6 - 1
<4>[12916.306158] ath10k_pci 0000:02:00.0: failed to install key for vdev 0 peer 30:d3:2d:7c:a1:3f: -110
<3>[12916.306181] wlan0: failed to remove key (0, 30:d3:2d:7c:a1:3f) from hardware (-110)
<3>[12948.979470] i915 0000:00:02.0: [drm] *ERROR* Atomic update failure on pipe A (start=777517 end=777518) time 385 us, min 1073, max 1079, scanline start 1067, end 1093
For the first two, I will try to post the dmesg that happen when freezing !
I have googled this, looks like a lot of people have disconection issues with this device, there are a lot of posts, I suggest you look through them, maybe someone solved this, but it looks like a firmware issue, you might need to buy a different card, looks like it’s swapable.
This can easily cause your screen to freeze. At least an explanation for your wifi issues, no idea why you have issues with a wired connection.
this is an an error from your intel graphics, maybe it’s caused by the wifi card, idk.
Might be a good idea to disable the intel graphics and only use your nvidia card, not ideal since it uses more power, but I don’t have a better idea.
