Hi! I recently encounter an issue inside endeavourOS or maybe is just in my machine. The probem is that whenever I star to record my screen with OBS or Simple Screen Recorded the output is tearing like crazy. I try to fix this out but I just break my plasma desktop.
I tried to enable the “tearfree” option in the /etc/X11/xorg.conf.d/20-intel.conf file like so:
Section "Device"
Identifier "Intel Graphics"
Driver "Intel"
Option "AccelMethod" "sna"
Option "TearFree" "True"
EndSection
Also I tried to change the option “sna” to “uxa” but it didn’t help. Even I tried to disabled virtual synchronization creating a file ~.drirc
<device screen="0" driver="dri2">
<application name="Default">
<option name="vblank_mode" value="0"/>
</application>
</device>
Here are my specs. Thanks in advance to anyoine who can help with this.
inxi -F
Host: endeavour Kernel: 5.14.16-arch1-1 x86_64 bits: 64
Desktop: KDE Plasma 5.23.2 Distro: EndeavourOS
Type: Laptop System: TOSHIBA product: Satellite U940
v: PSU6SP-01CLM1 serial: <superuser required>
Mobo: TOSHIBA model: VCUAA v: 1.00
serial: <superuser required> UEFI: TOSHIBA v: 1.20
date: 09/19/2012
Battery:
ID-1: BAT1 charge: 9.8 Wh (100.0%)
condition: 9.8/32.6 Wh (30.2%)
Info: Dual Core model: Intel Core i5-3317U bits: 64
type: MT MCP cache: L2: 3 MiB
Speed: 798 MHz min/max: 800/2600 MHz Core speeds (MHz):
1: 798 2: 1080 3: 1028 4: 857
Device-1: Intel 3rd Gen Core processor Graphics
driver: i915 v: kernel
Device-2: Chicony TOSHIBA Web Camera - HD type: USB
driver: uvcvideo
Display: x11 server: X.org 1.20.13 driver: loaded: intel
unloaded: fbdev,modesetting,vesa
resolution: <missing: xdpyinfo>
Message: Unable to show advanced data. Required tool
glxinfo missing.
Device-1: Intel 7 Series/C216 Family High Definition Audio
driver: snd_hda_intel
Sound Server-1: ALSA v: k5.14.16-arch1-1 running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet
driver: N/A
Device-2: Intel Centrino Wireless-N 2200 driver: iwlwifi
IF: wlan0 state: up mac: 9c:4e:36:81:87:cc
Bluetooth:
Device-1: Integrated System Solution Bluetooth Device
type: USB driver: btusb
Report: rfkill ID: hci0 state: up address: see --recommends
RAID:
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode]
driver: ahci
Local Storage: total: 495.58 GiB used: 234.91 GiB (47.4%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050
ID-2: /dev/sdb vendor: Samsung model: MZMPC032HBCD-00000
ID-1: / size: 28.68 GiB used: 20.81 GiB (72.5%) fs: ext4
dev: /dev/sdb2
ID-2: /boot/efi size: 511 MiB used: 296 KiB (0.1%) fs: vfat
dev: /dev/sdb1
System Temperatures: cpu: 50.0 C mobo: N/A
Fan Speeds (RPM): N/A
Processes: 230 Uptime: 30m Memory: 7.66 GiB
used: 2.42 GiB (31.6%) Shell: fish inxi: 3.3.07
