I have a laptop with a full hd screen in 16:9 and libreoffice looks ok
but when I start it with a second, bigger monitor connected, also in full hd, 16:10, the UI is scaled wrong
and if I start it without the second monitor connected, and then connect the second monitor and move the windows to it it looks huge
I tried to match their scaling, they were 125% (laptop) vs 100% and with both at 125% the situation is much better on the second monitor
but the windows of the programs working “correctly” are a bit too big on the second monitor now
commands tested
SAL_USE_VCLPLUGIN=kf6 libreoffice
QT_QPA_PLATFORM=wayland GDK_BACKEND=wayland libreoffice
Is there a way to set scaling for a single app, single monitor under wayland?
EDIT: leaving it here since it’s a known issue
Multiple screens with different scaling are affected by a bug preventing proper scaling on all screens. As a workaround start LibreOffice in Xwayland-mode (e.g.
WAYLAND_DISPLAY= libreoffice).
To make it global either add it to the desktop/menu icon or create a custom script (easier since you only need one for all the suite apps, but don’t forget you created it)
sudo nano /usr/local/bin/libreoffice
#!/bin/sh
export WAYLAND_DISPLAY=
exec /usr/bin/libreoffice “$@”
sudo chmod +x /usr/local/bin/libreoffice
it looks ok now
