Can I switch from my install already or will I have to do a clean install?
LOL! I actually had a guinea pig when I was a kid that looked pretty close to that one actually. Thanks for making it for me, yaāll are so nice! ![]()
Well you can install another desktop but iām not that big of a fan of it.
https://endeavouros.com/docs/pacman/how-to-install-desktop-environments-offline-install-users/
@linny
If you do end up installing another desktop environment all you have to do when you boot up into it is at the login screen change it to the desktop that you want to log into. It will be at the top right corner and just click on it and you will see the other desktop to select.
That is fixable. Set it to 200% and then increase the font size. I know that seems odd but the UI elements scale with the font so it will actually make everything bigger.
Cinnamon scaling is nearly identical to budgie scaling except it will also do some font adjusting for you. xfce scaling is not the best.
Hi @linny,
from what you show UP on screenshot, you miss factor 2x just try this :
gsettings set org.gnome.settings-daemon.plugins.xsettings overrides "{'Gdk/WindowScalingFactor', <2>}"
gsettings set org.gnome.desktop.interface scaling-factor 2
@FLVAL I wasnāt sure whether you could use the Gnome commands or not knowing that Budgie is based off of Gnome. I know that the Dell XPS 9380 has some quirks and i think is because of Intel setup.
Thanks everyone for all of your suggestions and help! I ran out of replies yesterday⦠I tried all of the DEās and decided on Deepin. Itās working out of the box now.
The only issues I have hadāwhich is really strange, is whenever I install redshift it makes my wifi go in and out. So to get around that I installed Blugon and itās working great now! Also spotify wonāt scale correctly, so Iām trying to figure out what to do about that.
I know Deepin is probably not the most secure, but maybe with Endeavor/Arch as the back-end it wonāt be as bad? (rhetorical question mostlyā¦) Besides, itās sooo pretty! SO thanks again to everyone who was willing to help this newbie! I think I am going to really like the Endeavor community, you are all so kind and helpful. Not like other forums for linux I have come across.
Hello @linny
I just came across this on an older Spotify forum and it may or may not work.
This might be the solution to your issue on Spotify with the HiDpi.
You could edit /usr/share/applications/spotify.desktop or where ever the .desktop file is located and change the line with Exec= to one of these factors: (1.5 2.0 2.5 3.0)
Exec=spotify --force-device-scale-factor=1.5 %U
Edit: You may have to log out and back in if you change the spotify config.
This may also work for the problem with other desktops but you would have to experiment.
Add --force-device-scale-factor=1.5 (or whatever fits your UI scale) as a command line option.
Hi @linny,
about trust of DEEPIN I used it for years before EndeavourOS, and if all Universities in the world distribute DEEPIN, You could be safe on itā¦
I remember you that the devs who work on DEEPIN live principaly at Whuan and You couldnāt catch Corona virus because of this⦠![]()
Here some info for you to read about DEEPIN :
Also the new DEEPIN V20 coming from the new portage of UOS for HUAWEI laptop will come soon, the corona virus slowed the launch date !
DEEPIN V20 is the same than UOS but without support for HUAWEI, like older DEEPIN version.
You could see here what DEEPIN V20 would be :
https://deepinenespaƱol.org/en/deepin-20-uos-rc-download-filtered/
In hoping, they will update the DE DEEPIN V20 cause the Barmenu system seems to be incredible !
This was supposed to launch Jan 2020? Havenāt seen it yet.
In fact, devs of DEEPIN worked on the UOS since the 19 July 2019 thatās why there is no update since this date on DEEPIN ! Then they explained that they will continue in DEEPIN V20 which is the same than new UOS but without support and will be open source like DEEPIN before, the both system are not for the same useā¦
Yes there are some ISO that circulated from UOS for few weeks but I would wait the official ISOā¦Deepin officially spoke about V20 in march but with the Corona virus it could be laterā¦
But we donāt know still, if a DEEPIN DE V20 would appear !!
@linny
Not sure if any of those suggestions work for the scaling but it was worth a try.
Itās my understanding that DEEPEN is only being developed for Debian, theyāre not spending time making sure it has fixes for other distroās . Thatās one of the reasons Mangaro stopped supporting DEEPIN.
@dalto any imput on that ?
I donāt have any inside information but my understanding was a little bit different.
I thought that Deepin was being developed for themselves and that a separate group had done the work to get it stable on Debian. Much in the same way that the Arch maintainers try to make it work for Arch. The real difference is that once you get it working on Debian it should mostly continue to work until a new version released. On Arch, it is more of an ongoing battle to keep everything working because of the rapidly rolling nature.
