Hi all - SANE/Airscan is not discovering my scanner - a HP Laser MFP 137fnw - over the local network. However, I am able to manually force the scanner to work (using skanlite as GUI frontend in this case) via the following command:
skanlite --device “smfp:net;192.168.0.XXX”
While that works, it’s still a pretty clunky way of doing things. Does anyone have any tips on how to make SANE remember the configuration?
Have you checked to see if that particular HP printer requires a plugin from HP in order for the scanner to work? If not, try running the following command from a terminal:
Turns out I already have the HPULD package installed. I also am aware that my printer works with driverless printing and I use IPP most of the time.
Do you mind me asking what your configuration options are? I think I need to manually edit some config files to ensure that my scanner “just works” whenever I open skanlite.
